Print at Sep 30, 2026, 11:23:51 PM
Posted by centi at Apr 16, 2013, 7:06:38 PM
sad   problem with make a Photo
i have Problem with draw up a Photo. SHD start to make a picture and a in a few seconds are the button Save aktivate but the picture ist not redy, only a view quader with circle RGBY inside on the picture. Where ist the Problem. My Processor is i5 2500 K and the Grafickard ist the Intel 3000 HD (inside proc).
Thanks for Help.
P.S:
Sweet Home is a great program!
thanks.
Peter
Posted by centi at Apr 17, 2013, 1:28:05 PM
Re: problem with make a Photo
[IMG]http://s1.directupload.net/images/130417/kglnwjcl.png[/IMG]
now you see it :-(
whats wrong?
Thanks for Help
Peter
Posted by Puybaret at Apr 17, 2013, 2:38:23 PM
Please send me your file. It's been a long time since this kind of bug wasn't reported, but maybe you found a new special case. What version of Sweet Home 3D do you use?
Posted by centi at Apr 17, 2013, 3:54:21 PM
thx for Answer.
my sweethome Version is Sweet Home 3D ® Version 4.0, DirectX, Java Version 1.6.0_43.
What of File will you have? .exe or?
Peter
Posted by Puybaret at Apr 17, 2013, 4:24:43 PM
Please send me the SH3D file of your home project, not the exe file.
Posted by Ludideco at Apr 23, 2013, 3:14:56 PM
same problem here !!!! :/
Posted by Puybaret at Apr 23, 2013, 6:56:29 PM
centi's issue was solved by increasing the max memory used by the program. Hope this will help.
Posted by Ludideco at Apr 23, 2013, 7:56:53 PM
Thanks !
Tryin to but i dont understand how you can write something in a folder... " write the max memory Java option in that file, for example -Xmx1024m"
Posted by Puybaret at Apr 23, 2013, 9:02:15 PM
You can use this file if you want to.
Posted by centi at Apr 24, 2013, 5:41:10 PM
hi,
yes that was the problem. THX for your help Puybaret!
download as first SweetHome3D-4.0.jar not forget those!
I just made ​​a start.bat with this content:
@ echo off
Java -Xmx4096m -jar "C:\Program Files (x86)\SweetHome3D\SweetHome3D-4.0.jar"
exit
and again a problem lass in this world peace biggrin
Peter
Posted by Jusmara at Apr 25, 2013, 12:46:55 AM
I hope someone here can help me. I know enough to know that I need to increase the memory usage for my program. I have the 64 bit java and sweethome.jar downloaded. My proplem is that I am a complete novice and I don't understand the instructions in the FAQ regarding......execute the java -Xmx4096m -jar path\to\SweetHome3D-4.0.jar command for 4 GB.......How exactly do I accomplish this? Can someone please give me step by step instructions? I am running windows 7 on my machine. I need this quick. My project is for a college course. It is due Monday. I have finished my design, but it is large and has a lot of furnishings. The program keeps locking up.
Posted by centi at Apr 25, 2013, 10:26:28 AM
Hi Jusmara,
my Email was blocket by your Provider!.
Peter
Posted by Puybaret at Apr 25, 2013, 10:44:44 AM
centi, couldn't you explain in the forum? It may be helpful for other users one day...
Posted by centi at Apr 25, 2013, 11:00:30 AM
Step by step (windows7 64bit):
download the file SweetHome3D-4.0.jar and save in to Folder "C:\Program Files (x86)\SweetHome3D\"
right mouse Key on Desktop -> new text file -> start.txt
rename start.txt into start.bat
edit the file and write the following into:
@echo off
{Java -Xmx4096m -jar "C:\Program Files (x86)\SweetHome3D\SweetHome3D-4.0.jar"}
exit
(between the {..} have to be in one line and without { }.)
save the file.
redy!
double-click this file and sweet home starts.
In this way, makes Sweet Home 3D no Problems.
Peter
Posted by Jusmara at Apr 25, 2013, 11:41:49 AM
Hello Centi and Emmanuel. Thanks for trying so hard to help me, but I am still a little bit lost. I have the sweethome file downloaded and saved into the correct folder (C:\Program Files (x86)\SweetHome3D) I am missunderstanding your instructions at the point that you say "right mouse Key on Desktop" I don't know exactly what you mean. If you mean to right click the mouse on my desk top, a window appears with a list of options starting with "view" and ending in "personalize" I don't think that is what you intend for me to do. If I understand your instructions, I need to find the file called "start.txt" then rename it "start.bat" I then open that file and write
@echo off
exit
Exactly as you have it above with the text between the {} all in one line but without the {}. Is that correct? If so, the first thing I need to know is exactly where and how to find "start.txt"
Posted by centi at Apr 25, 2013, 12:07:36 PM
yes I mean Desk top.
Sorry, my Windows talk German ;-)
right mouse key on free place on desktop, then new, and then textdokument.
Then you have a new file on desktop with name what you want.
You self can give the Name for this file, for example start.txt or sh3d.txt or what you want.
regards
Peter
Posted by Jusmara at Apr 25, 2013, 12:24:05 PM
Ok Peter. I have made the file and it is on my desktop. I named it sweethome start. When I double click it. It just opens the file and I see this.
@echo off
exit
Nothing actually happens other than the file I created is now open and I have the opportunity to change the code. Do I need to move the file somewhere else, or is the above code incorrect somehow. What you see here is copied and pasted from the file I created on my desktop.
Posted by centi at Apr 25, 2013, 12:28:53 PM
i wrote rename this file.txt in file.bat...
that's all
regards
Peter
Posted by Ludideco at Apr 25, 2013, 1:59:57 PM
Now sweet home closes automatically ! grrrrrrrr !
Posted by centi at Apr 25, 2013, 3:33:26 PM
while you work on sweet home
don't close the black window.
leave this window open or minimize it.
and you will be happy :-)
ragards
Peter
Posted by centi at Apr 25, 2013, 3:37:13 PM
when I have more time i try make it better.
Peter
Posted by Ludideco at Apr 25, 2013, 5:19:57 PM
thank you. for now it's good =)
Posted by Jusmara at Apr 25, 2013, 6:45:04 PM
Ludideco, Were you having the same problem as me? Were you able to get the memory successfully increased. I am seeing some improvement simply from running the sweethome jar version, but still really slow when trying to render pictures and so forth.
Posted by Jusmara at Apr 25, 2013, 6:47:45 PM
I have not been able to get past the road block that I ran into regarding what to do with the file that tells java to run at the 4gb range. Can anybody else help?
Posted by Puybaret at Apr 25, 2013, 7:32:31 PM
[...] but still really slow when trying to render pictures and so forth.
Don't dream, increasing the max memory used by the program, won't accelerate that much the rendering process. See also the FAQ How can I speed up the rendering process in photo and video creation panes?
If you want to run the program with 4 GB be sure to install a 64 bit version of Java first, and run the Sweet Home 3D with it. As the 64 bit version of Java is installed by default in C:\Program files\Java\jre6 the command in the bat file will become:
"C:\Program files\Java\jre6\bin\java" -Xmx4096m -jar "C:\Program Files (x86)\SweetHome3D\SweetHome3D-4.0.jar"
Posted by Ludideco at Apr 25, 2013, 9:41:05 PM
yes jusmara but now i have a problem running the program... when it opens and all and then when i try to reduce the plan and have a kind of full screen of the 3D image , or the other way around... it closes juste by moving the windows..
And the technicals words you guys are using ... well you may just speak chinese i'd understand just the same haha !
