Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Incorrect import 3DS model |
| Print at Sep 20, 2026, 1:20:27 AM | View all posts in this thread on one page |
| Posted by sergeynn at Feb 25, 2013, 11:45:21 AM |
Incorrect import 3DS model Hi. I try to import in sweethome3d this model, which is in 3DS format. But in sweethome3d this model looks doubled Please, help me to import correct model. |
| Posted by Puybaret at Feb 25, 2013, 12:07:07 PM |
Re: Incorrect import 3DS model It seems to be the same issue as the one mentioned in the FAQ The 3D view of Sweet Home 3D is always black or shows twice the same image. What can I do? Could you try if the proposed solution works for you? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Feb 25, 2013, 1:32:29 PM |
Re: Incorrect import 3DS model The model imports more or less correctly on my computer. Problems: - no textures; - windows aren't transparent; - imported model looks different from pictured model. This is a known problem with models from this website. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by sergeynn at Feb 25, 2013, 1:57:47 PM |
Re: Incorrect import 3DS model In my case, only this model shows twince. Other models (also from this site) shows normally. And 3D view of sweethome is normal. I use sweethome in Linux. Who can convert this model to another format fo me? |
| Posted by hansmex at Feb 25, 2013, 2:15:22 PM |
Re: Incorrect import 3DS model I also use Linux (Ubuntu 12.04), so it's not a Linux problem, but a problem of your computer. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by sergeynn at Feb 25, 2013, 6:46:48 PM |
Re: Incorrect import 3DS model Hans, if your computer import this model correctly, can you save it to another format which i can import correctly? |
| Posted by hansmex at Feb 25, 2013, 8:49:21 PM |
Re: Incorrect import 3DS model No, I can't. As I wrote, there are several problems with the model, most importantly that the glass isn't transparent. So, what use would windows be, if you can't see through them?? Hans ![]() ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by sergeynn at Feb 27, 2013, 2:46:40 PM |
Re: Incorrect import 3DS model So, if it don't work, i do so. 2 different model - window and door. Window i have done. Now i need door. But i can't find door wich is from 2 section - top and bottom. Top section is transparent, bottom is not transparent. Does anybody have door model which i need? |
| Posted by hansmex at Feb 27, 2013, 3:20:25 PM |
Re: Incorrect import 3DS model Americans call this a Dutch door when you can open top and bottom half separately. Or else search for a door with glass pane. A bit of fantasy goes a long way... Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 1:20:27 AM |
