Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to turn wall into round |
| Print at Oct 6, 2026, 7:01:41 AM | View all posts in this thread on one page |
| Posted by mnadeem at Feb 15, 2013, 6:24:54 PM |
How to turn wall into roundHi i can not turn wall in to round with mouse in any degree , |
| Posted by Puybaret at Feb 15, 2013, 6:46:38 PM |
Re: How to turn wall into round As indicated in the help and in the FAQ, you should keep pressed the ctrl key (or alt key under Mac OS X) while clicking at the end point of a wall. The arc extent of the round wall will depend on the point where you'll click the next time. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Feb 15, 2013, 6:48:08 PM |
Re: How to turn wall into round In case it's too complicated for you, you can also change it afterwards with the modification pane of a wall. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mnadeem at Feb 16, 2013, 9:45:30 PM |
Re: How to turn wall into roundTHanks its works , we doom bin i shoulsd have readen the pdf file ,, thanks any way thats why the expert are there . So jets other ?: can i png and bmp file convert or put into my list of things if so then how |
| Posted by Puybaret at Feb 17, 2013, 1:52:25 PM |
Re: How to turn wall into round can i png and bmp file convert or put into my list of things if so then how If you mean Is it possible to import the picture of a piece of furniture and make it appear as a 3D object?, no it's not possible. But you can use a simple box, and apply the image you want on its faces after importing your image as a texture.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mnadeem at Feb 18, 2013, 10:38:15 AM |
Re: How to turn wall into roundBut you can use a simple box, and apply the image you want on its faces after importing your image as a texture. Hi i did not understand what you have mention ,, please advise Second , i have try to take pic or mov can not do it comes (x) cross . Where i am making wrong , need any plugins , i have latest version v3.7 |
| Posted by mnadeem at Feb 20, 2013, 2:52:37 PM |
Re: How to turn wall into roundHi i have found that if there is import background image then if it is not properly adjest . photo or video will not be taken . But my ? is how can we know what kinds of images is running becouse in list such thing is not present again thanks in regards |
Current timezone is GMT Oct 6, 2026, 7:01:41 AM |
