Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: downlight light source? |
| Print at Sep 20, 2026, 7:23:49 AM | View all posts in this thread on one page |
| Posted by malc_b at Nov 16, 2012, 8:56:05 PM |
downlight light source? Hi, Is there a downlighter light source around anywhere? I've sort of faked one up by putting a light source in a tube but the effect doesn't match what I expect to see. TIA |
| Posted by Puybaret at Nov 19, 2012, 12:06:17 AM |
Re: downlight light source? Using light sources should be enough, unless you want to display them turned off. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by malc_b at Nov 19, 2012, 1:38:55 AM |
Re: downlight light source? I assume a light source model is a point source with equal intensity in all directions? Downlighters have a limited angle (MR16 bulbs are 36deg to the 50% points I think). So a 180deg source will not give the same effect. Is it easy to make a light source with varying intensity? |
Current timezone is GMT Sep 20, 2026, 7:23:49 AM |
