Print at Sep 20, 2026, 6:24:10 PM
Posted by malc_b at Nov 16, 2012, 8:56:05 PM
downlight light source?
Is there a downlighter light source around anywhere? I've sort of faked one up by putting a light source in a tube but the effect doesn't match what I expect to see.
TIA
Posted by Puybaret at Nov 19, 2012, 12:06:17 AM
Re: downlight light source?
Using light sources should be enough, unless you want to display them turned off.
Posted by malc_b at Nov 19, 2012, 1:38:55 AM
I assume a light source model is a point source with equal intensity in all directions? Downlighters have a limited angle (MR16 bulbs are 36deg to the 50% points I think). So a 180deg source will not give the same effect. Is it easy to make a light source with varying intensity?
