Print at Sep 29, 2026, 4:21:48 PM
Posted by 00turkey at Nov 3, 2012, 11:08:29 AM
How To Make Roof ?
I Am very very bad english, expression is picture please :)
My Question : How To Make A Roof ?
Allready Thanks :)
Posted by Puybaret at Nov 3, 2012, 12:28:47 PM
Re: How To Make Roof ?
Please read the FAQ How can I create a roof on top of a house?
Posted by 00turkey at Nov 3, 2012, 6:35:01 PM
thankss :D
Posted by Mo at Dec 12, 2012, 5:13:10 PM
Hi, I'm new. Learning how to create rooms was quite easy. But the creation of roofs even with this tutorial is still a hard job.
Are there any plans to improve the roof creation for next versions?
I managed the part of the tutorial until page 9 where I used the "Copy as new furniture"-plugin and pasted. But I don't get the roof pasted to the walls and I don't get the triangles created like that.
For our project the most important is creating the room dimensions of our little house. I could work without roof, but actually to get a real impression it would be important to add a roof.
Posted by Puybaret at Dec 12, 2012, 6:39:30 PM
As explained in the FAQ, Sweet Home 3D doesn't support the creation of roofs until now, and the proposed tutorial gives some workarounds found by Hans, a super user of Sweet Home 3D.
I plan to add a tool to create some roofs in a future version but sorry, this probably won't happen before months.
Posted by Mo at May 3, 2013, 5:28:00 PM
Hi. I guess the new 4.0 version did not give any progress for roofs?
Currently I feel like SweetHome3D(SH3D) is good for flats and multi-stage flats, but not for houses. I deliberated long for which tool I would use for planning the house. Professional ones like Catia V5 (not mentioning the price of course) can do all detailed stuff for 3D, but when it comes to furnishing SH3D is a very quick approach, and portable, which was the main reason for me having Linux/Windows, and even different archs up to Linux on PPC.
What is the current state for house environments such as gardens? So far I have only seen some trees to arrange, but it should not be that hard to arrange all different types of plants on a plain map, when the models are there.
Posted by Puybaret at May 6, 2013, 7:02:35 PM
No, maybe in a coming version...
Keep in mind that Sweet Home 3D first targets interior design.
Gardens would require some "terra forming" tool to give the various elevation points of the ground, and more models of plants and trees. This kind of 3D models are complicate to design, so it will take probably years before a complete library of this kind appears, according to contributors proposals.
Posted by amechax at Jun 19, 2015, 10:01:51 AM
I have made triangles out of red slate roof designed by Emmanuel Puybaret find them here
I 'll improve it over time
Posted by Strikkie at Dec 7, 2015, 10:35:37 PM
When I follow the tutorial and I create a a room the drawing is on the height of the groundfloor but I can not get it on the level of the roof, how can I change the height of the layer?
Posted by HawkDawg at Dec 8, 2015, 12:54:56 AM
To get a room on a different level than the ground floor you have to add a level, which is found under the Plan tab. When you add a level you can set it's height in that settings window.
You can also adjust the height of the new level later under the Plan tab again by selecting Modify level.
Hawk
Posted by Strikkie at Dec 9, 2015, 1:41:35 PM
Hi Hawk, hows life in the US?
Thanks for the info but what I ment was that I need to tilt a floorpart to use it as a sloop roof..... I find it a little difficult to get it right.
I have seen a post from you of a 8angle roof of which you can not fill the parts perhaps you can recall the post, it was from 2014.
I'll keep on trying thanks
Posted by HawkDawg at Dec 9, 2015, 2:40:48 PM
That tutorial I linked to in another post should help to explain how to do that.
That tutorial works best for simple roofs though. The trick is when you import the saved obj file that you created using walls. When importing you have to rotate it to get it like you want.
Life in the US used to be a lot better. It's rapidly going downhill, in my opinion.
I don't think this is the place to discuss that though. wink
Hawk
Posted by HawkDawg at Dec 9, 2015, 2:47:12 PM
After reading that tutorial on sloping ceilings, I built the roofs in this house .
Hawk
Posted by MimicaDreamer at Dec 27, 2015, 9:20:41 AM
Tools
Where is the tool-place button which give the new furniture in SW.
I made according to your instruction of the roof but I can not get it into a new furniture to make the upstairs roof.
