Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Texture import ok; showing later 'all wrong'.... |
| Print at Aug 14, 2026, 5:40:16 AM | View all posts in this thread on one page |
| Posted by Gaytan at Oct 22, 2012, 3:26:56 PM |
Texture import ok; showing later 'all wrong'.... Hi Guys, When I import a new texture; in particular the one at the first link, importing via wizard goes ok. I choose 168 x 168 and it appears ok: http://cl.ly/image/1s1O2f330u3o When I use it in my home, it shows all wrong: http://cl.ly/image/193h3v0R2n2c Anybody got any clue what is going wrong with it? Using Mac with SH3D 3.6; working great for the rest! Tried to file a bug but don't have a userid there (yet)... Grtz! ![]() |
| Posted by hansmex at Oct 22, 2012, 4:02:59 PM |
Re: Texture import ok; showing later 'all wrong'.... Ed, This isn't a Mac bug, it's a problem in SH3D or in the Java-3D software it uses. The problem lies in the way (a) the triangles on the surface of objects are applied or (b) SH3D applies textures on a surface or (c) a combination of the above. The only workaround that I know, is to design a made-to-measure object using a different 3D program, or to make a thorough study of the OBJ "language" and learn how to apply the texture directly from within the OBJ code. Try applying your texture to a box, then rotate the box to look at all sides. You'll see similar effects. I once managed to construct a box with correct textures on all vertical faces using the method described above. It wasn't easy. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Oct 22, 2012, 5:25:36 PM |
Re: Texture import ok; showing later 'all wrong'.... Applying a texture on a cylinder or a tube doesn't work the same way as applying it on a cube. If you want to apply your texture, please download the attached 3D model and replace the tube.jpg image it contains by yours using the same file name. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Gaytan at Oct 22, 2012, 7:04:05 PM |
Re: Texture import ok; showing later 'all wrong'.... Oh wow, didn't realize 'things could be soo difficult'! hihihi Thanks for your outstanding support; both Emmanuel AND Hans! You guys AND this software amaze me each and every day really! I'm going to apply the tube.zip later, Emmanuel; I understand your explanation! Am addicted to this program really! I really love it! :-) |
Current timezone is GMT Aug 14, 2026, 5:40:16 AM |
