Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problem 3D with SH3D 3.5 |
| Print at Sep 25, 2026, 2:48:17 AM | View all posts in this thread on one page |
| Posted by brownemmett at Sep 1, 2012, 10:44:58 PM |
Problem 3D with SH3D 3.5 Hello boys, i have a problem with SH3D 3.5 on my slackware linux 13.37. I have this graphics video "Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller" and it work with "i915" module. Normaly the graphic video work correct, when i start SH3d 3.5, the 3d window it's black. This problem found with all 3.x release while with 2.x release i see the 3d image but while i work, it crash and i have this error in "dmesg": Please help me Regards |
| Posted by hansmex at Sep 2, 2012, 9:10:29 AM |
Re: Problem 3D with SH3D 3.5 Emmett, Did you check the section in the FAQ that deals with video problems? Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by brownemmett at Sep 2, 2012, 1:02:28 PM |
Re: Problem 3D with SH3D 3.5 Hello Hansmex, in the FAQ i don't founded this problem. I think that it's a new problem Regards |
| Posted by hansmex at Sep 2, 2012, 2:21:31 PM |
Re: Problem 3D with SH3D 3.5 Emmett, I'm using Ubuntu 12.04, and it works perfectly. Under Linux: Did you try these solutions already?- Update the drivers of your graphic card with the latest available ones, and try to run Sweet Home 3D again. - If this update doesn't fix your problem, click on this link to run Sweet Home 3D with an older version of the Java 3D library. If it works, 3D performances and rendering won't be as good as with default Sweet Home 3D version. - If this solution still doesn't work, you may finally want to use Sweet Home 3D without 3D features, by reading the answer to the next question. You could also try to do a double install, installing Ubuntu as a second choice. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Sep 2, 2012, 2:44:31 PM |
Re: Problem 3D with SH3D 3.5 brownemmett, as you can guess, I can't test Sweet Home 3D on all Linux variants available out of there, but this sounds like a problem in your graphics driver. Does a program like Art of Illusion work correctly? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by brownemmett at Sep 2, 2012, 7:44:45 PM |
Re: Problem 3D with SH3D 3.5 Hello Puybaret, i have tried ArtofIllusion and i have similar problem. I don't see the 3d images. I have last driver of the i915. If i run "glxinfo | grep render" i see that rendering is enabled What can it be? |
| Posted by brownemmett at Sep 4, 2012, 6:00:54 PM |
Re: Problem 3D with SH3D 3.5 Hello boys, i have install on my notebook "slackware current 64" and after installation, i have same problem. The old version was slackware 13.37 32bit and it had same problem. I think that problem is the driver of Intel Graphics or the driver is incompatible. have you any idea? Thank you boys |
| Posted by brownemmett at Sep 6, 2012, 6:49:20 PM |
Re: Problem 3D with SH3D 3.5 I have update the "mesa" driver from 7.9.2 to 7.10.2 and i resolve the problem with Opengl. Sweet Home 3D and all 3D software work correctly. Thank you boys |
| Posted by Puybaret at Sep 6, 2012, 6:53:24 PM |
Re: Problem 3D with SH3D 3.5 Great to read you found the right driver update ![]() Have fun with Sweet Home 3D! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 2:48:17 AM |
