Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Copy as new furniture Plugin Source Code |
| Print at Sep 19, 2026, 6:55:47 PM | View all posts in this thread on one page |
| Posted by dimm at May 24, 2012, 5:42:27 PM |
Copy as new furniture Plugin Source Code Can anyone share or point to the Plugin source code? I checked the repository but it is not there. |
| Posted by sclee at May 24, 2012, 7:31:58 PM |
Re: Copy as new furniture Plugin Source Code http://www.sweethome3d.com/plugins/CopyAsNewFurniturePlugin-1.1.sh3p |
| Posted by dimm at May 24, 2012, 7:40:13 PM |
Re: Copy as new furniture Plugin Source Code Thanks for your comment sclee, I have the plugin. I'm looking for the source code. |
| Posted by sclee at May 24, 2012, 7:59:00 PM |
Re: Copy as new furniture Plugin Source Code You try to change the file ".sh3p" to".zip",".zip" file extract. |
| Posted by dimm at May 24, 2012, 8:49:42 PM |
Re: Copy as new furniture Plugin Source Code Thanks |
| Posted by jfs51765 at Mar 7, 2015, 2:42:17 PM |
Re: Copy as new furniture Plugin Source Code i need help as to where i can download "copy as new furniture and advanced edit plugins, i just installed the latest SH3d 4.6v on my pc with win7. Thanks in advance for the assistance. |
| Posted by hansmex at Mar 7, 2015, 3:35:24 PM |
Re: Copy as new furniture Plugin Source Code The function of the CopyAsNewFurniture plugin has been integrated in SH3D. You don't need the plugin anymore. It works as follows" - select the model that you want to export - click 3D View --> Export to OBJ format - give a name and click Save - select Export selection You can then import the model again. On the Documentation page you can download a tutorial for plugins. It also gives the locations where you can download them. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Mar 7, 2015, 3:38:08 PM |
Re: Copy as new furniture Plugin Source Code The function of the CopyAsNewFurniture plugin has been integrated in SH3D. You don't need the plugin anymore. The CopyAsNewFurniture plugin still provides something that Export to OBJ format doesn't support: it's also able to copy (then paste) lights included in the selection.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 19, 2026, 6:55:47 PM |
