Print at Sep 19, 2026, 9:26:51 PM
Posted by dimm at May 24, 2012, 5:42:27 PM
Copy as new furniture Plugin Source Code
Can anyone share or point to the Plugin source code?
I checked the repository but it is not there.
Posted by sclee at May 24, 2012, 7:31:58 PM
Re: Copy as new furniture Plugin Source Code
http://www.sweethome3d.com/plugins/CopyAsNewFurniturePlugin-1.1.sh3p
Posted by dimm at May 24, 2012, 7:40:13 PM
Thanks for your comment sclee,
I have the plugin. I'm looking for the source code.
Posted by sclee at May 24, 2012, 7:59:00 PM
You try to change the file ".sh3p" to".zip",".zip" file extract.
Posted by dimm at May 24, 2012, 8:49:42 PM
Thanks
Posted by jfs51765 at Mar 7, 2015, 2:42:17 PM
i need help as to where i can download "copy as new furniture and advanced edit plugins, i just installed the latest SH3d 4.6v on my pc with win7.
Thanks in advance for the assistance.
Posted by hansmex at Mar 7, 2015, 3:35:24 PM
The function of the CopyAsNewFurniture plugin has been integrated in SH3D. You don't need the plugin anymore.
It works as follows"
- select the model that you want to export
- click 3D View --> Export to OBJ format
- give a name and click Save
- select Export selection
You can then import the model again.
On the Documentation page you can download a tutorial for plugins. It also gives the locations where you can download them.
Posted by Puybaret at Mar 7, 2015, 3:38:08 PM
The CopyAsNewFurniture plugin still provides something that Export to OBJ format doesn't support: it's also able to copy (then paste) lights included in the selection.
