Print at Sep 14, 2026, 1:36:53 AM
Posted by guidaccio at May 3, 2012, 12:38:41 PM
angry   SH 3D do not start
Hi! My problem is after the installation (I've alredy tried to use the online and jsp method, but it doesn't seems work!).
When I launch the application i can see only the starting window, then the program crashes (without signal) and i find this report on my desktop:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6954ac8e, pid=3516, tid=1452
# JRE version: 7.0_04-b20
# Java VM: Java HotSpot(TM) Client VM (23.0-b21 mixed mode, sharing windows-x86 )
# Problematic frame:
# C [atioglxx.dll+0x51ac8e]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
I've an Ati Radeon 9550 series...
Help me, what I can do???
Posted by Puybaret at May 3, 2012, 1:22:18 PM
Re: SH 3D do not start
It's probably due to a problem in the video driver of your computer. See the FAQ for suggestions about how to fix it.
