Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to select all objects in all levels |
| Print at Sep 25, 2026, 2:01:32 PM | |
| Posted by txwikinger at Apr 8, 2012, 6:17:39 AM |
How to select all objects in all levels I have created a multi-level structure and would like to move all objects that are part of it. Hoow can I do this? Thanks |
| Posted by Puybaret at Apr 8, 2012, 1:40:50 PM |
Re: How to select all objects in all levels You can select all the lines in the furniture list at bottom left, and copy paste it if needed. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by txwikinger at Apr 11, 2012, 9:38:28 PM |
Re: How to select all objects in all levels Yes, but I need to select all objects, not only furniture, i.e. also the walls and rooms from the other levels |
| Posted by Puybaret at Apr 11, 2012, 10:00:23 PM |
Re: How to select all objects in all levels It's not possible at this time. But I wonder why you need such a feature. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by cnanu2000 at Apr 12, 2012, 10:11:51 AM |
Re: How to select all objects in all levels Hi, It works for me. I can select all or part of any object\s and copy paste to othe level floor. I used it to copy exterior walls from one floor to other. HTH Nanu |
| Posted by Puybaret at Apr 12, 2012, 8:11:54 PM |
Re: How to select all objects in all levels cnanu2000, I guess txwikinger wants to select all objects in all levels at the same time. I wouldn't mind to program this feature but as it will need some programming to show to the user that all levels are selected, I prefer to have some interesting use case before starting. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Jobil at Jul 16, 2012, 12:29:22 AM |
Re: How to select all objects in all levels Hi, I have the same need. My use case is to design also the outdoors. So I would like to move the entire house in the building plot. Thank you in advance Jobil |
| Posted by cleveroff at Dec 21, 2012, 2:16:58 AM |
Re: How to select all objects in all levels I have the same need too. I have two seperated plans, one with house, another with bath-house. Both plans have many levels. Now I want to merge these plans in one file. Help! |
| Posted by cleveroff at Dec 22, 2012, 1:22:46 AM |
Re: How to select all objects in all levels Probably I understood, that it is impossible. Because the dimensions of levels in both plans are too different. |
Current timezone is GMT Sep 25, 2026, 2:01:32 PM |
