Total posts in this thread: 9
Previous Thread This topic has been viewed 4211 times and has 8 replies Next Thread
txwikinger
How to select all objects in all levels
I have created a multi-level structure and would like to move all objects that are part of it. Hoow can I do this?
Thanks
[Apr 8, 2012, 6:17:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to select all objects in all levels
You can select all the lines in the furniture list at bottom left, and copy paste it if needed.
[Apr 8, 2012, 1:40:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
txwikinger
Yes, but I need to select all objects, not only furniture, i.e. also the walls and rooms from the other levels
[Apr 11, 2012, 9:38:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's not possible at this time. But I wonder why you need such a feature.
[Apr 11, 2012, 10:00:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cnanu2000
It works for me.
I can select all or part of any object\s and copy paste to othe level floor.
I used it to copy exterior walls from one floor to other.
HTH
Nanu
[Apr 12, 2012, 10:11:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cnanu2000, I guess txwikinger wants to select all objects in all levels at the same time. wink
I wouldn't mind to program this feature but as it will need some programming to show to the user that all levels are selected, I prefer to have some interesting use case before starting.
[Apr 12, 2012, 8:11:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Jobil
I have the same need. My use case is to design also the outdoors. So I would like to move the entire house in the building plot.
Thank you in advance
Jobil
[Jul 16, 2012, 12:29:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cleveroff
Latvia
I have the same need too. I have two seperated plans, one with house, another with bath-house. Both plans have many levels. Now I want to merge these plans in one file. Help!
[Dec 21, 2012, 2:16:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cleveroff
Latvia
Probably I understood, that it is impossible. Because the dimensions of levels in both plans are too different.
[Dec 22, 2012, 1:22:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
