Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Staircase not visible in upper level |
| Print at Sep 20, 2026, 3:25:34 PM | |
| Posted by sokre_zg at Mar 20, 2012, 2:27:48 PM |
Staircase not visible in upper level Hi. I created my own staircase using AOI, and imported it as on .OBJ into my project (I'm using SH3D v3.4). The thing is, I cannot see this staircase on the floorplan of the upper level. This also happens with models converted from .SKP to .DAE. Could someone please help? |
| Posted by Puybaret at Mar 20, 2012, 8:08:28 PM |
Re: Staircase not visible in upper level I cannot see this staircase on the floorplan of the upper level. Not sure I completely understand what you mean. If your staircase isn't higher enough, it won't be seen at the upper level and if you didn't check the Staircase option at the third step of the furniture import wizard, no hole in the floor will be computed.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sokre_zg at Mar 21, 2012, 9:49:45 AM |
Re: Staircase not visible in upper level It's about the height...! Staircase height was set to wall height + floor thickness, and it must be a little bit more to be visible on both levels. Thanks a lot |
Current timezone is GMT Sep 20, 2026, 3:25:34 PM |
