Previous Thread This topic has been viewed 2790 times and has 2 replies Next Thread
sokre_zg
Staircase not visible in upper level
Hi.
I created my own staircase using AOI, and imported it as on .OBJ into my project (I'm using SH3D v3.4). The thing is, I cannot see this staircase on the floorplan of the upper level. This also happens with models converted from .SKP to .DAE.
Could someone please help?
[Mar 20, 2012, 2:27:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Staircase not visible in upper level
Not sure I completely understand what you mean. If your staircase isn't higher enough, it won't be seen at the upper level and if you didn't check the Staircase option at the third step of the furniture import wizard, no hole in the floor will be computed.
[Mar 20, 2012, 8:08:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sokre_zg
It's about the height...!
Staircase height was set to wall height + floor thickness, and it must be a little bit more to be visible on both levels.
Thanks a lot
[Mar 21, 2012, 9:49:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
