Print at Jul 27, 2026, 11:50:47 PM
Posted by Cmbellomo at Mar 9, 2012, 6:28:53 PM
How do I calculate total floor area or room square footages?
Hello,
I am new to Sweet Home and am really happy with the features.
How do I calculate the square footage of the total floor plan or individual rooms so that it displays on my plan? I have searched for the answer but would appreciate any advice.
Thank you,
Chris
Posted by Puybaret at Mar 9, 2012, 7:36:31 PM
Re: How do I calculate total floor area or room square footages?
Click on the Create rooms tool and then double click on an exterior wall. This will create a room covering the whole home including the walls (it's not really a feature but you can use it in the current version 3.4). If you want something more accurate and you can program, you could create a plugin that will add the area of all the rooms.
Posted by Cmbellomo at Mar 12, 2012, 4:37:49 PM
Great, thank you. That works. But do you know if the area is calculated to the inside or outside of the perimeter walls and are there settings to adjust?
Has anyone created a plug-in to calculate area or sf for all rooms? Where could I check for developed plug-ins?
Thanks,
Chris
Posted by hansmex at Mar 12, 2012, 5:55:21 PM
Chris,
Areas are calculated from the centerline of walls, i.e. the lines determined by the X,Y coordinates.
A tutorial, including a list, for all available plug-ins can be found here.
Posted by Puybaret at Mar 12, 2012, 6:39:46 PM
Moving the room area would have shown you that it includes the wall area (as said in my previous answer)
No, as far as I know.
Posted by matt01 at Mar 20, 2016, 7:32:48 PM
If you draw a 10x10 box, it gives you 95 sf. Draw a line through it and it is less so it doesn't include interior walls. You have to take out for exterior walls too because it calculates it wrong. To find the exterior wall space of a 10x10 room, you must convert 3 in wall. divided by 12=.25 x 10=2.5, then times 4 is 10 sf. If it counted the exterior walls it would be 105 sf., not 95, is way off.
Posted by Puybaret at Mar 22, 2016, 9:49:00 AM
Matt, the displayed area of a room object doesn't take into account the other objects at its border or upon it.
