Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: change height of walls after a lot oft work |
| Print at Sep 6, 2026, 3:09:14 PM | |
| Posted by Einrichter2012 at Feb 6, 2012, 8:10:19 PM |
change height of walls after a lot oft work Hello, I already spend a lot oft time planning our house - now I realised that I missed to change the wallheight from standard 2.50m to 3.30 - does anybody know a way out? Thanks the lot! *D |
| Posted by hansmex at Feb 6, 2012, 8:16:25 PM |
Re: change height of walls after a lot oft work Daniel, 1 - Select your wall(s) 2 - Do a right-click 3 - Select Modify walls 4 - Enter the new wall height(s) 5 - If you are using multiple levels, you will also have to adjust the Elevation in the level settings by double clicking the Level tab. Suggestions: 1 - Read the User's guide 2 - Start using the Help pages in the program. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 3:09:14 PM |
