Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problem importing furniture; colors disappear/wrong |
| Print at Sep 6, 2026, 9:12:32 AM |
| Posted by oshkoshbigoshforjosh at Jan 22, 2012, 11:48:04 PM |
Re: Problem importing furniture; colors disappear/wrong Ok, so now I have gotten to the point where I can import a DAE into SweetHome 3D and it appears totally correct in the new furniture import setup windows but when I go to hit the final button and have it enter the room the actual piece goes all white! |
| Posted by hansmex at Jan 23, 2012, 12:02:21 AM |
Re: Problem importing furniture; colors disappear/wrong When you download a DAE model, it consists of the DAE file and a separate directory that contains the textures. If you move the file to a different location, you should move the texture directory as well. If you don't do that, you end up with white models. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by oshkoshbigoshforjosh at Jan 23, 2012, 12:05:19 AM |
Re: Problem importing furniture; colors disappear/wrong What does the textures directory look like? I dont see anything which looks like it is the file I am saving it in |
| Posted by oshkoshbigoshforjosh at Jan 23, 2012, 12:11:41 AM |
Re: Problem importing furniture; colors disappear/wrong You are amazing! I created a new folder to save the DAE file in. When I did so I discovered that a copy of the photograph which I used for the basis of the texturing was saved in that file and that is when it hit me-that the texture files would be external files that the DAE ( and probably OBJ?!?) would access, not that they would have saved within themselves. So then I immediately bundled the DAE with the PNG into a zip and imported the zip and VIOLA!!! Thank you so much for your help today and your patience as I stumble through, thrashing and grabbing everything afloat around me. |
Current timezone is GMT Sep 6, 2026, 9:12:32 AM |
