Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Change center-position in 3D aerial mode |
| Print at Sep 29, 2026, 4:00:01 AM |
| Posted by pial at Feb 10, 2012, 4:15:31 PM |
Re: Change center-position in 3D aerial mode You're right Ivedin. That's why so many users come up against that zoom limit : it is for sure the biggest drawback of the so useful aerial view mode. Can we hope an improvement (or an answer at least) on that particular point ? ---------------------------------------- ---------------------- Pierre |
| Posted by macfrog at Feb 12, 2012, 8:50:41 PM |
Re: Change center-position in 3D aerial mode To add my tiny opinion here, i would be glad if there is a way to "straighten" the angles; e.g. to make to aerial view _exactly_ 90 degrees and not alittle bit kindof 89,221 or something else. i would like a "center" button, really. i need my walls mostly aligned to other pictures of a similar project. this is impossible, especialy at higher resolutions every "misplaced" walls are terrible. greetz macfrog |
| Posted by Sajmmon at Sep 5, 2012, 9:13:12 PM |
Re: Change center-position in 3D aerial mode A partial solution to the 3D view limitations is to center the camera onto a mass center of selected objects. It is quite easy to implement. For those who are interested I give a link to a movie where such mechanism is implemented, have a look around 2:30 : http://www.youtube.com/watch?v=I98AJZO7fJ0 The Wuteh 3d Studio tool from the movies is based on a modification license of SH3D. |
| Posted by speed777777 at Sep 26, 2012, 6:34:09 PM |
Re: Change center-position in 3D aerial mode HELLO, just stumbled upon this, shall i call it a fiasco, people having a go at the developer of something that they get for NOTHING, my opinion is if this program which is FREE does not satisfy you, theres always LUMION for only 3 thousand pounds, i am willing to bet my life that it will satisfy all your needs. just my very tiny opinion. shaun |
| Posted by Puybaret at Sep 26, 2012, 8:42:35 PM |
Re: Change center-position in 3D aerial mode Shaun, this is just a wishlist. And like any wish, discussing about it doesn't mean it will happen. Anyway the idea of Sajmmon seems interesting and there are some good chances that a new Aerial view centered on selection preference will appear in next version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by szymi at Apr 3, 2014, 5:49:59 PM |
Re: Change center-position in 3D aerial mode Hello. My apologies for posting on an old thread, but I found a simple way of changing the center of 3D view. I know there is now an "official" way of doing it described in the FAQ section, but changing the center by selection gets a little anoying when you want to move furniture around and at the same time to see your changes in aerial mode. My way of changing the center is to create a large room around the home (catching some area around it as well). The room may be square or rectangular, depending on what results you want to get. Make sure the floor is not visible. The center of the room is the center of your aerial view. You can move the room around to move the center. The room can be placed on an extra level below level 1 so that it does not get in your way when moving furniture around. Hope this tip will be useful to someone. Szymon |
| Posted by okh at Apr 4, 2014, 12:07:02 AM |
Re: Change center-position in 3D aerial mode A good workaround and a sensible point :-) (even with the implemented centre on selection)... ok |
Current timezone is GMT Sep 29, 2026, 4:00:01 AM |
