Print at Aug 25, 2026, 12:13:22 AM View all posts in this thread on one page
Posted by fanyam at Nov 18, 2011, 2:21:07 PM
How can I create wall skirting and color it?
I've learnt how to create walls. I also want to give them skirting with different colors but I could not find how to do it.
Could anyone teach me how to do it?
Thanks
Posted by hansmex at Nov 18, 2011, 2:29:38 PM
Re: How can I create wall skirting and color it?
Fanyam,
The "new" way to create skirting, or two-coloured walls, is to use the new Levels feature, available in the current 3.4 beta versions .
- Draw your wall(s) on Level 1.
- Create a new level and draw the same wall(s) again.
- Give the wall(s) on Level 1 and Level 2 a different colour or texture.
Read the info in the thread I pointed to, to learn more on how to use this feature, and to download examples.
Posted by Puybaret at Nov 18, 2011, 3:12:34 PM
fanyam, I would simply use long boxes (from Miscellaneous category) placed along the wall.
Hans, even if it could work, levels weren't designed as a workaround for skirting! What would be the advantage of using them compared to simple boxes?
Posted by fanyam at Nov 19, 2011, 4:05:49 AM
After I tried both methods, using boxes seems rather simple and easy to manage. Thank you both of you. I like SweetHome. :)
Posted by BLAlley at Nov 19, 2011, 5:05:07 AM
I agree with the box idea. In the example, I set the depth of the bow to 1", height to 48", and imported the image of a tile wainscot to the same height so it wouldnt repeat. The wainscot looks dimensional even though it's flat because the photo was of tile and a chair rail.
I use boxes, spheres, and cylinders for all kinds of things
Oh well. This forum doesnt allow local photos I guess. Use your imagination to see what I did.
Posted by macfrog at Nov 19, 2011, 9:19:30 PM
Hi folks,
i just explained this rather obvious solution in another thread for a similar question; the language is different but there are pictures visible.... smile
http://www.sweethome3d.com/support/forum/viewthread_thread,2711#12342
macfrog
