Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How can I create wall skirting and color it? |
| Print at Aug 25, 2026, 12:53:32 AM | |
| Posted by fanyam at Nov 18, 2011, 2:21:07 PM |
How can I create wall skirting and color it? I've learnt how to create walls. I also want to give them skirting with different colors but I could not find how to do it. Could anyone teach me how to do it? Thanks |
| Posted by hansmex at Nov 18, 2011, 2:29:38 PM |
Re: How can I create wall skirting and color it? Fanyam, The "new" way to create skirting, or two-coloured walls, is to use the new Levels feature, available in the current 3.4 beta versions . - Draw your wall(s) on Level 1. - Create a new level and draw the same wall(s) again. - Give the wall(s) on Level 1 and Level 2 a different colour or texture. Read the info in the thread I pointed to, to learn more on how to use this feature, and to download examples. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Nov 18, 2011, 3:12:34 PM |
Re: How can I create wall skirting and color it? fanyam, I would simply use long boxes (from Miscellaneous category) placed along the wall. Hans, even if it could work, levels weren't designed as a workaround for skirting! What would be the advantage of using them compared to simple boxes? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by fanyam at Nov 19, 2011, 4:05:49 AM |
Re: How can I create wall skirting and color it? After I tried both methods, using boxes seems rather simple and easy to manage. Thank you both of you. I like SweetHome. :) |
| Posted by BLAlley at Nov 19, 2011, 5:05:07 AM |
Re: How can I create wall skirting and color it? I agree with the box idea. In the example, I set the depth of the bow to 1", height to 48", and imported the image of a tile wainscot to the same height so it wouldnt repeat. The wainscot looks dimensional even though it's flat because the photo was of tile and a chair rail. I use boxes, spheres, and cylinders for all kinds of things Oh well. This forum doesnt allow local photos I guess. Use your imagination to see what I did. |
| Posted by macfrog at Nov 19, 2011, 9:19:30 PM |
Re: How can I create wall skirting and color it? Hi folks, i just explained this rather obvious solution in another thread for a similar question; the language is different but there are pictures visible.... http://www.sweethome3d.com/support/forum/viewthread_thread,2711#12342 macfrog |
Current timezone is GMT Aug 25, 2026, 12:53:32 AM |
