Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Rendering problem |
| Print at Aug 6, 2026, 5:46:39 AM |
| Posted by Puybaret at Sep 29, 2011, 12:21:02 PM |
Re: Rendering problem Your timezone / longitude values aren't homogeneous. At 11 AM in Taipei, it's dawn at a longitude/latitude set in Europe, and the result is correct for these parameters. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by quickmic at Sep 30, 2011, 4:32:58 PM |
Re: Rendering problem I also have render problems. Some pixel-error can be seen... Here: https://rms-systems.homelinux.net/download/Transfer/Pic.jpg |
| Posted by hansmex at Sep 30, 2011, 5:23:21 PM |
Re: Rendering problem Quickmic, Can you use a TRUSTED website to host your images? Firefox refuses to open it. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by quickmic at Sep 30, 2011, 5:27:51 PM |
Re: Rendering problem I don't wanna pay für an official cerificat but you can ignore the warnings... Else use this: http://www.megaupload.com/?d=G05R2AW0 |
| Posted by hansmex at Sep 30, 2011, 6:36:39 PM |
Re: Rendering problem You may want to have a look at www.mediafire.com .... But even with the black spots, it's a VERY nice image! ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by devilbliss at Oct 1, 2011, 4:26:06 AM |
Re: Rendering problem Ah ok emmanuel, thanks! Sorry for overlooking the timezone values, im not familiar with those. But its really cool that you've incorporated the timezone values in rendering photos in the program. |
| Posted by devilbliss at Oct 1, 2011, 4:35:38 AM |
Re: Rendering problem Nice quickmic! where did you get the wooden planks that you used for your room? thanks! |
| Posted by Puybaret at Oct 1, 2011, 10:33:14 AM |
Re: Rendering problem Sorry for overlooking the timezone values, im not familiar with those. It's an other reason why you should choose the default photo rendering dialog of Sweet Home 3D v 3. It uses some code able to best guest your longitude/latitude for your default time zone, but the older Advanced rendering plugin doesn't use it (and I don't think I will update this plug-in).---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by quickmic at Oct 1, 2011, 8:41:20 PM |
Re: Rendering problem Nice quickmic! where did you get the wooden planks that you used for your room? thanks! Thats just normal textures. I loaded picture templates from the Web and modified them. The Trick is, that you must make sure that the Textures don't have borders if they are merged. -> If you found a nice picture, modify it by mirroring in any directions. Here are some of mine. [Note from moderator: removed link to quickmic's textures library since he's not sure they can be redistributed] |
| Posted by Puybaret at Oct 1, 2011, 8:56:10 PM |
Re: Rendering problem quickmic, I don't want to be boring and appreciate your will to share your findings, but did you check you have the right to redistribute these images before posting them? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 6, 2026, 5:46:39 AM |
