Print at Sep 21, 2026, 3:55:42 AM
Posts: 13   Pages: 2   [ Previous Page | 1 2 ]
Posted by inkstain44 at Jul 29, 2011, 11:24:38 PM
Re: How can I access auto recovery files? I just lost all of my work!
I've been using sweet home for.. 2 or 3 years.. Never had any problems like this
Posted by Puybaret at Jul 30, 2011, 12:28:41 PM
Thanks for the information. This is the information I need, but as I can't view the screenshot you posted, I would be also pleased to read the lines following:
at java.util.zip.ZipInputStream.getNextEntry(ZipInputStream.java:73)
From this first part, you must be using a 3D model with non ASCII characters or wrongly encoded characters, or your SH3D file is wrong, and from Java sources, there were some changes from Java 1.5 to Java 1.6 about this possible problem. If you run Sweet Home 3D under Java 1.6, it may have worked or if it failed, an error dialog would have appeared at least.
Then I guess you run Sweet Home 3D under Java 1.5 (see About Sweet Home 3D dialog box), right? What Mac OS X version are you running?
Can you send me your buggy file, so I check myself?
Posted by selfilm at Nov 1, 2022, 1:19:25 PM
Hello,
I had a similar situation that I just went through and any help would be greatly appreciated. I was saving all along the way without the system giving me any issues. But when I went to find those files, even though I saved all along the way, they were just text files, with shortened names, and had nothing in their memory? I am very confused and lost 2 days worth of precious work. Any help would be greatly appreciated.
