Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Some Questions (Rendering, Ubuntu, 64bit,....CAD) |
| Print at Sep 27, 2026, 7:21:06 PM | |
| Posted by noxx at Jun 21, 2011, 3:17:50 PM |
Some Questions (Rendering, Ubuntu, 64bit,....CAD) hello, i ve some questions about sweethome3d, i hope anyone can answer. - is it possible to make more as one picture with the rendering function? i mean, i position (2x or 3x or 4x,..)the camera like in the video menĂ¼ and sweet home make over night the different rendering pictures and save this in a custom folder. - how can i use sweet home under win7 (64bit) as 64bit-programm? i try it with ubuntu-64, but unfortunately ubuntu is nothing for me. - is it possible to accelerate sweet home rendering (or rendering plugin: advance rendering) ? Win 64 bit, 6gb Ram, DualCore 2x 2gHz Pixel ~2000x1400 Glossy / Turn on celling lights / Turn on lamps / Glossy Floors --> 3,5 hours thats very slow - is it possible to export the building/room in a CAD compaible format, like *.stp / *.igs / *.sat / *.wrl / ... ? regard |
| Posted by hansmex at Jun 21, 2011, 3:45:49 PM |
Re: Some Questions (Rendering, Ubuntu, 64bit,....CAD) Ralf, I don't have all the answers, but here's a start. 1 - more pictures in one go Unfortunately that isn't possible: one picture at a time. But it's a good idea for a feature request. 2 -accelerate rendering There isn't a "turbo" button in SH3D, but there are a few things that you should bear in mind: - the more lights (lamps, bulbs, etc) you add, the longer the rendering takes - make all models invisible that will NOT be visible in the image you're taking; this reduces the rendering time considerably 3 - CAD compatible formats SH3D saves/exports its data in OBJ format. Your best guess would be to use Blender or on online service to convert your model to a different format. And by the way... 3.5 hrs isn't exactly bad for a 2000x1400 pix picture (depending on the file size). Also, programs generally run faster under Ubuntu than they do under Windows (I'm a Ubuntu-64 user). Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by noxx at Jun 21, 2011, 5:13:30 PM |
Re: Some Questions (Rendering, Ubuntu, 64bit,....CAD) ok, thx for the answer. about ubuntu: - how i INSTALL sweet home 3d? - how i Install Plugins? i dont found a folder .etek/../../ |
| Posted by hansmex at Jun 21, 2011, 5:43:36 PM |
Re: Some Questions (Rendering, Ubuntu, 64bit,....CAD) Ralf, 1 - To install SH3D: From the Download page: Under Linux: Uncompress the downloaded file and run SweetHome3D application found in the uncompressed directory. To install Sweet Home 3D, move the uncompressed directory in the one of your choice. 2 - To install plug-ins (and use them)From the Documentation page: Tutorial for plug-ins and extensions Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by noxx at Jun 21, 2011, 10:23:30 PM |
Re: Some Questions (Rendering, Ubuntu, 64bit,....CAD) 2 - To install plug-ins (and use them) From the Documentation page: Tutorial for plug-ins and extensions where can i find the .etek folder? can you make a screenshot from your plugin folder, so that i can see the complete data path? regard |
| Posted by Puybaret at Jun 21, 2011, 10:43:05 PM |
Re: Some Questions (Rendering, Ubuntu, 64bit,....CAD) where can i find the .etek folder? First it's .eteks not .etek ![]() You don't have to create it. To install a SH3P or SH3L file under Linux, right click on the file and choose to open it with the SweetHome3D program found in its installation folder. is it possible to accelerate sweet home rendering (or rendering plugin: advance rendering) ? Prefer the built-in renderer to the advanced rendering plugin. From David's tests, it's much faster. Please read also the FAQ How can I speed up the rendering process in photo and video creation panes?how can i use sweet home under win7 (64bit) as 64bit-programm? See the FAQ How can I adjust the memory used by Sweet Home 3D?---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by noxx at Jun 21, 2011, 11:01:50 PM |
Re: Some Questions (Rendering, Ubuntu, 64bit,....CAD) java -Xmx4096m -jar path\to\SweetHome3D-3.2.jar is it possible to make a shortcut? i put the SweetHome3D-3.2.jar in my lib folder an make a shortcut on my desktop to this file. but if i change in the properties from "C:\Program Files (x86)\Sweet Home 3D\lib\SweetHome3D-3.2.jar" to java -Xmx4096m -jar "C:\Program Files (x86)\Sweet Home 3D\lib\SweetHome3D-3.2.jar" windows show a error ? regard |
| Posted by noxx at Jun 21, 2011, 11:25:05 PM |
Re: Some Questions (Rendering, Ubuntu, 64bit,....CAD) i change the shortcut to C:\Windows\System32\java.exe -Xmx4096m -jar "C:\Program Files (x86)\Sweet Home 3D\lib\SweetHome3D-3.2.jar sweethome run, i hope this is correct!??!?!?! regard |
| Posted by noxx at Jun 21, 2011, 11:38:45 PM |
Re: Some Questions (Rendering, Ubuntu, 64bit,....CAD) it seems not correct, Java use only 400-500MB of my RAM... Screenshot: http://s7.directupload.net/file/d/2562/oe8vlkho_jpg.htm |
| Posted by hansmex at Jun 22, 2011, 12:15:11 AM |
Re: Some Questions (Rendering, Ubuntu, 64bit,....CAD) Ralf, Since you're new at Ubuntu, here are a few tips: 1 - To install SH3D you only have to unzip it. It will create a folder called SweetHome3D (or similar) with all the files and subfolders needed. You can place this folder wherever you want, because no programs point back to this folder. 2 - To run SH3D do this: open the folder in which SH3D is installed and look for the file called SweetHome3D. Its size is 771 bytes. Right-click on the file, select Properties, then click the tab Permissions. Make sure that the checkbox "Allow to run as a program" is active. Now close the dialog. Double-clicking the file SweetHome3D should run the program, although maybe you have to confirm this by clicking Run in a pop-up window. If all is well, you should now be able to use the program and make your first design. 3 - To find the .eteks folder, proceed as follows: open the file manager, then type CTRL-H on the keyboard. This shows all Hidden directories and files. Now you can locate the .eteks folder. I hope this helps you get started. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Jun 22, 2011, 8:58:47 AM |
Re: Some Questions (Rendering, Ubuntu, 64bit,....CAD) it seems not correct, Java use only 400-500MB of my RAM... The -Xmx Java option sets the maximum memory used by Sweet Home 3D. That doesn't mean so much memory will always be used! If you want Sweet Home 3D to use 4096 MB from the start, you should try -Xms4096m option, but I don't believe it's useful in Sweet Home 3D unless you want to check it works.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 7:21:06 PM |
