Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Looking for construction libraries and symbols |
| Print at Sep 26, 2026, 9:52:00 PM | |
| Posted by Mystic_fool at Jun 10, 2011, 8:09:48 AM |
Looking for construction libraries and symbols I need more staircase configurations, and electrical symbols. Are these available from Sweet Home 3D, or is there somewhere I can download them from? Thanks |
| Posted by Mystic_fool at Jun 10, 2011, 8:22:57 AM |
Re:
Looking for construction libraries and symbols Forgot to mention, I'm using a Mac. |
| Posted by Puybaret at Jun 10, 2011, 9:00:35 AM |
Re: Looking for construction libraries and symbols Didn't you find what you're looking for among all the models and link in the 3D models import page? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Jun 10, 2011, 9:14:22 AM |
Re: Looking for construction libraries and symbols electrical symbols ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Mystic_fool at Jun 10, 2011, 5:00:54 PM |
Re: Looking for construction libraries and symbols Didn't you find what you're looking for among all the models and link in the 3D models import page? No. What's really needed is a variety of simple staircase configurations, that will show detail in 2D, and hopefully work in 3D as well. A lot of the staircases available on the 3D model page, do not show any detail in 2D, they just look like rectangles boxes, plus there are not enough configurations. Example of what I'm looking for: ![]() |
| Posted by Mystic_fool at Jun 10, 2011, 5:07:11 PM |
Re: Looking for construction libraries and symbols I get error messages when I try to use any Google Sketchup files with Sweet Home 3D. Am I missing something here? |
| Posted by hansmex at Jun 10, 2011, 5:41:49 PM |
Re: Looking for construction libraries and symbols Check the Google Sketchup Warehouse for all your needs... If necessary install Sketchup to convert models from SKP to DAE format. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Mystic_fool at Jun 13, 2011, 12:09:52 AM |
Re: Looking for construction libraries and symbols Check the Google Sketchup Warehouse for all your needs... If necessary install Sketchup to convert models from SKP to DAE format. Thanks, I was able to figure out how to convert SKP to DAE, using Google Sketchup. Question though, I don't see much use in a whole page of electrical symbols. There's no way to separate any one symbol, for use in floor plans. I'm I missing something here? Thanks |
| Posted by hansmex at Jun 13, 2011, 12:55:59 AM |
Re: Looking for construction libraries and symbols In Sketchup you can easily use Edit -> Group -> Explode to ungroup the symbols, then delete all but one, and export it as DAE. Then Undo the deletion and save another symbol you need. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Mystic_fool at Jun 14, 2011, 4:24:06 PM |
Re: Looking for construction libraries and symbols In Sketchup you can easily use Edit -> Group -> Explode to ungroup the symbols, then delete all but one, and export it as DAE. Then Undo the deletion and save another symbol you need. Thanks, I was able to separate symbols, but the quality was such, that they will not work for blueprints. Not sure if there is anything that can be done about that. |
| Posted by Puybaret at Jun 14, 2011, 4:38:15 PM |
Re: Looking for construction libraries and symbols The other option is to create larger plan icons as I suggested in the other thread you opened. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 9:52:00 PM |
