Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Removing objects from library |
| Print at Sep 22, 2026, 3:07:06 AM | |
| Posted by Frador2 at May 9, 2011, 11:53:16 PM |
Removing objects from library Is it possible to remove objects from the library once I've imported them? I thought I read somewhere that it was possible, but I can't find where I read it. |
| Posted by hansmex at May 10, 2011, 12:02:35 AM |
Re: Removing objects from library Frador, How you remove a model from the library, depends on how the model was added. 1 - You imported the model Just right-click on the model, and choose delete. 2 - The model is a model that came in a library file (SH3F) Use the LibraryEditor (see manual PDF) to open the library. Delete the file from the library. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by wrosun at May 10, 2011, 6:20:04 AM |
Re: Removing objects from library well about this.I inported furniture through some .sh3f file i created before and now there are some furnitures which appear more then twice in the library any tip for removing those. can furniture library editor help me....? |
| Posted by hansmex at May 10, 2011, 8:59:47 AM |
Re: Removing objects from library wrosun, Read the previous post, please. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Frador2 at May 10, 2011, 4:10:53 PM |
Re: Removing objects from library It was from a library file. I have the Library Editor, but where can I find the library or libraries to edit them? I've looked everywhere I can think of. Obviously I'm missing somewhere. ![]() I even tried to uninstall and reinstall SH3D, but all the libraries I imported are still there, even with the new install. |
| Posted by Frador2 at May 10, 2011, 4:13:19 PM |
Re: Removing objects from library Just a quick note. I love this program. ![]() |
| Posted by Puybaret at May 10, 2011, 4:52:16 PM |
Re: Removing objects from library See the Libraries of additional 3D models section in the 3D models page. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Frador2 at May 10, 2011, 7:02:29 PM |
Re: Removing objects from library Found the solution and I'm including it here so it's here for anyone else to find. I use Windows 7 and the App Data folder is a hidden file. If you can't find it, you have to go to Control Panel\ Appearance and Personalization\ Folder Options and check Show Hidden Files, etc. |
Current timezone is GMT Sep 22, 2026, 3:07:06 AM |
