Print at Oct 1, 2026, 2:18:44 AM View all posts in this thread on one page
Posted by wmigda at May 3, 2011, 7:49:24 PM
GLX problems with Mesa Rendering
I have downloaded Linux tarball with SweetHome3D 3.2. My system's got:
- xorg server 1.9.4,
- mesa 7.10.1,
- very old ATI RagePro card working at the 1280x1024 resolution,
- Samsung SyncMaster 971P TFT display,
All that running under Gentoo.
eselect lists two interfaces for opengl, I'm using xorg-x11 one:
$ eselect opengl list
Available OpenGL implementations:
[1] xfree
[2] xorg-x11 *
glxinfo reports:
$ glxinfo
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_MESA_copy_sub_buffer, GLX_INTEL_swap_event
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap,
GLX version: 1.4
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: Gallium 0.4 on softpipe
OpenGL version string: 2.1 Mesa 7.10.1
OpenGL shading language version string: 1.20
OpenGL extensions:
GL_ARB_copy_buffer, GL_ARB_depth_texture, GL_ARB_draw_buffers,
GL_ARB_draw_elements_base_vertex, GL_ARB_explicit_attrib_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_framebuffer_object, GL_ARB_half_float_vertex,
GL_ARB_map_buffer_range, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_occlusion_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_provoking_vertex,
GL_ARB_shader_objects, GL_ARB_shader_stencil_export,
GL_ARB_shading_language_100, GL_ARB_shadow, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_swizzle,
GL_ARB_transpose_matrix, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture, GL_EXT_draw_buffers2,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_object,
GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_polygon_offset, GL_EXT_provoking_vertex, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_shader_objects,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture3D, GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture,
GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_swizzle,
GL_EXT_timer_query, GL_EXT_vertex_array_bgra, GL_EXT_vertex_array,
GL_OES_EGL_image, GL_OES_read_format, GL_APPLE_packed_pixels,
GL_APPLE_vertex_array_object, GL_ATI_blend_equation_separate,
GL_ATI_separate_stencil, GL_ATI_texture_env_combine3,
GL_ATI_texture_mirror_once, GL_IBM_multimode_draw_arrays,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_window_pos,
GL_MESA_ycbcr_texture, GL_NV_blend_square, GL_NV_conditional_render,
GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_primitive_restart, GL_NV_texgen_reflection,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
---more listing follows---/snip
When I run SweetHome3D it crashes withthe following:
SweetHome3D-3.2 $ ./SweetHome3D
javax.media.j3d.IllegalRenderingStateException: Can't create graphics environment for Canvas 3D
at com.eteks.sweethome3d.j3d.Component3DManager.getCanvas3D(Unknown Source)
at com.eteks.sweethome3d.j3d.Component3DManager.getOnscreenCanvas3D(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.SwingViewFactory.createView3D(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController3D.getView(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.createActions(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown Source)
at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$2.collectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.run(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$3.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
I know that my card is severly outdated, but I've got Mesa for software rendering. What is going wrong here ?
Thanks in advance,
Wojciech
Posted by Puybaret at May 4, 2011, 9:48:16 AM
Re: GLX problems with Mesa Rendering
Could you try whether the version based on Java 3D 1.3 works or not on your computer, and read also the FAQ if you didn't yet?
Posted by wmigda at Oct 4, 2011, 4:02:10 PM
1. it looks like 16-bit color depth was the problem,
2. On ubuntu I can run SH3D in 24-bit depth,
3. On gentoo it starts, but then java crashes when I attempt to create the photo (I'm investigating right now).
BR,
Wojtek
