Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: The SH3D file failed to load on the web using Sweet Home 3D Viewer |
| Print at Sep 6, 2026, 9:42:10 AM |
| Posted by yizhou at Apr 16, 2011, 6:51:19 PM |
The SH3D file failed to load on the web using Sweet Home 3D Viewer Hi all, while open the file "SweetHome3DViewer.html" in the web browser to check if it works correctly, the message like this:正在加载家具模型...,but the SH3D file wasn't loaded successfully in the past 12 hours. What can I do? Thanks a lot~ |
| Posted by Puybaret at Apr 17, 2011, 1:55:09 AM |
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer I don't know if your problem is bound to the same problem as the one mentioned in this thread, but the version 3.1 of the viewer is buggy. Please, use the previous version 3.0, until the version 3.2 is released. By the way, a translation of 正在加载家具模型 (even if partially accurate) would be helpful. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by yizhou at Apr 17, 2011, 8:50:31 AM |
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer Thanks a lot Puybaret. Everything is fine now. BTW, I want to edit the she3d file online, what can I do? |
| Posted by yizhou at Apr 18, 2011, 4:34:02 PM |
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer Ping... |
| Posted by Puybaret at Apr 18, 2011, 10:08:21 PM |
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer Editing the SH3D file is more complicate, because you have to decide how to load the file from the server, how to save it and who should be allowed to do these operations (that's why I don't distribute a compiled version Sweet Home 3D applet until now). I can give you some hints but if you have no knowledge about web server programming technologies like PHP, JSP or ASP, this is going to be very difficult for you. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by yizhou at Apr 19, 2011, 6:35:31 AM |
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer Hi Puybaret, thanks for your response~ Hmm,I think I have knowledge about web server programming technologies like PHP, JSP and ASP,so could you give me some hints? thanks again~ |
| Posted by Puybaret at Apr 19, 2011, 3:50:35 PM |
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer You should download Sweet Home 3D source code, read its README.TXT file, run applet Ant target, test SweetHome3DApplet.html script, adapt readHome.php and writeHome.php files to your needs after reading SweetHome3DApplet parameters. Reading also this thread and that one should be useful. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by yizhou at Apr 19, 2011, 6:28:10 PM |
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer Thanks a lot Puybaret. Will do. |
| Posted by yizhou at Apr 20, 2011, 8:14:27 PM |
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer Hi Puybaret, while building Sweet Home 3D(http://prdownloads.sourceforge.net/sweethome3d/SweetHome3D-3.1-src.zip) with Ant,here no SweetHome3DApplet.jar in deploy/lib but SweetHome3D.jar. While testing SweetHome3DApplet.html, the error message like this:can't find class com.eteks.sweethome3d.applet.SweetHome3DViewer.Look like the class "applet" is missing in SweetHome3D.jar,right? Thanks a lot~ |
| Posted by Puybaret at Apr 20, 2011, 10:57:11 PM |
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer You have to run applet Ant target to build SweetHome3DApplet.jar file, for example with the command: ant applet---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 9:42:10 AM |
