Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Sweet Home 3D don't execute |
| Print at Sep 20, 2026, 7:26:03 PM | |
| Posted by dubrocards at Mar 18, 2011, 2:57:24 PM |
Sweet Home 3D don't execute Hi everyone, I'm using SH3D (v3.0) durng several days without problem. Since 4 days now when I launch SH3D i just have the screen "Sweet Home 3D" and it stay on the display. I must kill the process in the task manager. I reinstall the SH3D v3.0 then v3.1. The problem is still there. I reinstall Java, then SH3D. The problem is still there. I follow the FAQ, but it don't work for me. My configuration is : - Core 2 Duo Intel 3 GHz - 4 Go of RAM - Windows 7 Pro (64 bits) - nVidia GeForce 9500 GT (512 Mo) Somebody can help me ? Thanks |
| Posted by Puybaret at Mar 19, 2011, 1:49:18 PM |
Re: Sweet Home 3D don't execute If the program used to run and you tried every tip cited in the 3D problems FAQ, I would suspect a recent update of your video card driver. Did you try also to increase max memory? Setting a number too big could prevent the program from running. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by dubrocards at Mar 19, 2011, 4:32:15 PM |
Re: Sweet Home 3D don't execute No I didn't increase memory. After I had this problem I update the video card driver but the problem is still there. I had at home this configuration : - Athlon 4200+ - 4 Go of RAM - Windows 7 Pro (64bits) - nVidia GeForce 9500 GT (1024 Mo) And everything work fine. I don't know what I can do ? Thanks again for any help. |
| Posted by dubrocards at Mar 21, 2011, 6:04:44 PM |
Re: Sweet Home 3D don't execute Hi everyone, Sweet Home 3D work again on my office desktop. I deleted SH3D, Java and my graphic's drivers. I deleted also all de directories SH3D and Java in subdirectorie "user\AppData\Roaming" and "user\AppData\Local". Then I installed graphical's drivers, SH3D and JAVA. Everything run fine now. Thanks for reading me. |
Current timezone is GMT Sep 20, 2026, 7:26:03 PM |
