Print at Sep 19, 2026, 8:45:08 PM
Posts: 34   Pages: 4   [ Previous Page | 1 2 3 4 ]
Posted by yocarbo at Aug 29, 2012, 4:45:21 PM
Re: 2 floor restaurant.
Hello,
Thank you for your response, but I used 2 différents PC DELL with ATI or Intel video card.
I'm on 64bits, make a difference ?
I use already the installed version.
I have tested without java installed and in command line with different version of java (1.6.0_32 and 1.7.0_06) and executable jar :
java -jar SweetHome3D-3.5.jar
but no success sad
Regards,
Posted by hansmex at Aug 29, 2012, 6:25:30 PM
Yo,
One of the suggestions done earlier is to do a "normal" Copy-Paste operation. Example: Open your text processor Writer (?), type some text, now Copy and Paste it.
If that causes (more or less) the same problem(s), maybe something is wrong with the clipboard function.
One other thing about using CopyAsNewFurniture: the copy that you make, is put exactly on top of the original. Sometimes it may seem as if no copy has been made, when in fact (invisibly) the copy is right on top of the original.
One other cause of problems, in rare cases, is the model that you are trying to copy. If that model is faulty, than sometimes it may cause strange behaviour. You can easily test this by trying to copy some kind of standard furniture in an otherwise empty SH3D design.
Finally, maybe you can try a third computer with Ubuntu 32-bits installed? Or make a dual-install?
Posted by yocarbo at Aug 29, 2012, 10:10:14 PM
applause   Re: 2 floor restaurant.
HANSMEX YOU ARE A GENIUS ! biggrin
the solution is very simple ... pfff ! idea
On KDE, an application manages the copy/paste : klipper !
I have desactivated this application and "bazinga", it's worked fine ! dancing
Thank you for your big help, I can continue my project for my house with this simple, efficient and magnifique program SH3D ! wink
Best regards,
Posted by Yuri_fromBY at Sep 1, 2012, 9:59:18 AM
The originator of a similar problem in Ubuntu 12.04 was clipboard manager Diodon.
