Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Floor Rendering Problem |
| Print at Oct 1, 2026, 12:04:07 AM |
| Posted by wrosun at Dec 19, 2010, 12:35:59 PM |
Floor Rendering Problem Hello! friends Here is a problem i observed,The problrm is about creating floors. if a single floor(room) is created for whole house then it appears while rendering but if diffenent floors are created then only the floor which is created at first is seen while rendering I dont hink i explained well so here are some pictures to show what i mean ![]() IN THIS ONE I USED COLOR/DEFAULT TEXTURES/USER MADE TEXTURE ![]() AS YOU CAN SEE NON OF THESE WORK OUT. |
| Posted by Puybaret at Dec 19, 2010, 12:49:32 PM |
Re: Floor Rendering Problem It's probably the same problem as macfrog. I never saw it happen yet. Can you send me your wrong SH3D files please? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Dec 19, 2010, 1:20:55 PM |
Re: Floor Rendering Problem wrosun, I tried to copy this behaviour but without success. I copied your designs exactly, created the first room in the same place, I used four imported textures. and applied textures to the walls. It renders perfectly in aerial view and virtual visitor view. Can you check the size of the images you use for your textures? Not only how big the file is (in Kb) but also the size in pixels. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Dec 19, 2010, 1:47:50 PM |
Re: Floor Rendering Problem Hans I don't think it's a matter of size. From the screen captures, even some texture images coming from Sweet Home 3D (256x256 pixels) aren't displayed. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by wrosun at Dec 19, 2010, 2:02:01 PM |
Re: Floor Rendering Problem well this is a file i created in 5 min to show you guys and any model i create shows same problem. Yup it is same problem as MACFROG. First i thought it was some thing he did but i tries it and when ever i make models shows the problem. @HANS: This problem is same if i create room in other places at first only that room shows floor .I dont think its is pixel problem hans because when i use default textures only also then there is the same problem and if i create first room using user texture then the rooms will show texture while rendering... @puybaret: I will attach a sh3d file showing the problem,File I have done every thing but the problem is always there. ![]() |
| Posted by Puybaret at Dec 19, 2010, 2:12:44 PM |
Re: Floor Rendering Problem Too bad, I don't have any problem to render the file you posted at the 2 best quality levels. If I can't reproduce the problem, I won't be easy to fix. From you screen captures, I see you tried to compute the images with the Advanced rendering plug-in. Could you try with Sweet Home 3D default photo creation dialog? I don't think it will change anything for you, since macfrog used this dialog too, but who knows what can happen with furtive bugs? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Dec 19, 2010, 2:14:09 PM |
Re: Floor Rendering Problem wrosun, Thanks for the file. On my computer (operating system is Ubuntu 10.10) they render perfectly. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by wrosun at Dec 19, 2010, 2:18:36 PM |
Re: Floor Rendering Problem Really? well i havent tried it with Ubuntu. My operating system is Windows 7 home premium if you can try with it once some how then may be you will see the problem....can there be problem with my computer??? |
| Posted by Puybaret at Dec 19, 2010, 2:29:24 PM |
Re: Floor Rendering Problem can there be problem with my computer? No I don't think so.On my side, I tried under Windows 7 and Mac OS X successfully. By the way, wrosun, your avatar looks nice. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by wrosun at Dec 19, 2010, 2:38:09 PM |
Re: Floor Rendering Problem @Puybaret: May be i should have told you before that the rendering with default photo creation dialogue works perfectly in any quality mode.I am having problems in advanced rendering plug-in. ![]() Thanks! ![]() |
Current timezone is GMT Oct 1, 2026, 12:04:07 AM |
