Print at Sep 14, 2026, 3:38:44 AM
Posted by fhoofman at Dec 3, 2010, 7:19:26 PM
the render stop before it finish
I'm using version 3
and i tried to use my last project and tried to render and I was hoping that the render is faster & more realistic.
but render always stops before it finish
actually. it stops after about 10 seconds, and button "save" is enabled before the render show its result
what did i do wrong?
i installed version 3 before uninstall version 2.6
Posted by Puybaret at Dec 3, 2010, 7:28:50 PM
Re: the render stop before it finish
Yudi, please try with default Create photo feature.
To be sincere, I'm not even sure I tried once the Advanced rendering photo during the development of Sweet Home 3D version 3.0. I should have but I didn't, and I'm not sure I'll maintain the plug-in anyway.
Note that you can still use Sweet Home 3D 2.6 and 3.0 on the same computer.
Posted by fhoofman at Dec 3, 2010, 7:45:21 PM
i'm afraid that using default create photo feature just give me the same result
Posted by hansmex at Dec 3, 2010, 8:31:46 PM
Yudi,
A few things you could try:
1 - save your model, close SH3D, restart it, load your model and try again
(I think SH3D has some strange memory allocation problems, and with a "clean" memory you can render bigger designs)
2 - (temporarily) delete furniture that doesn't show in the photo you want to make, then make your render in a clean machine
3 - (temporarily) delete plants and trees outside the visible area, as these take up a lot of resources during rendering
4 - share your file and I'll be happy to have a look at it
Posted by Puybaret at Dec 3, 2010, 8:41:12 PM
Yudi,
You can send your file to me also if Hans suggestions don't fix your problem. I'll have a look at it with a debugger that will help me find the problem.
Nice layout by the way! smile
Posted by fhoofman at Dec 4, 2010, 5:04:49 PM
I've done what Hans told me to. but seems not working yet.
here's the file
files
feel free for anyone to learn my design smile
Posted by hansmex at Dec 4, 2010, 5:13:57 PM
Yudi,
Thanks for sharing your file. On my (Ubuntu) PC the render stopped after a few seconds. I'll have to investigate what the cause is. As soon as I know more, I will post it here.
EDIT
I already have a suspect.
The couch and the staircase are 3DS files, which you probably imported as a zip-file. Inside the file are also gsm-files. Try to unzip the file and import only the 3ds file, without the gsm part. Maybe that will solve the problem.
When I delete the three tangga files, the rest renders without a problem.
END EDIT
Posted by Puybaret at Dec 4, 2010, 7:13:36 PM
The problem probably comes from one the 3D models, but not from the GSM files.
I fixed the bug in the source code but... I won't be available until version 3.1 or an intermediate beta version.
Thank you for sharing it help me to fix the bug.
Posted by fhoofman at Dec 4, 2010, 8:29:50 PM
from my design,
here's render from version 2.6
and here's from version 3 after deleting 2 tangga files
I think i learn something here smile
thanks Hans
