Print at Aug 24, 2026, 12:36:56 AM View all posts in this thread on one page
Posted by hansmex at Dec 3, 2010, 5:57:42 PM
Wishlist version 3.1
Emmanuel,
The progress in the development of SH3D over the last year has been enormous. So many new features have been included, that the program has matured beyond expectations. This includes several of the excellent plug-ins contributed by users.
Of course there is always room for improvement. The roadmap for version 4 sounds exciting, and I can hardly wait for the day v4 will be announced. Nevertheless, there are a number of smaller wishes and issues that could solve all kind of small problems.
Now, you know very well how eager I am to see layers and roofs, but I have decided to be modest this year. So, instead of asking for version 4, may I ask for version 3.1? Most, if not all, of these things have been asked before. Where possible I have added the link to the thread/post in the forum.
My version 3.1
PREFERENCES
- add option to choose between 12/24 hrs system
WALLS
- add a simple and intuitive Join Walls feature (feature in AdvancedEdit plug-in is too complex)
DATA ENTRY
- fix issues with jumping cursor when entering dimensions
DOORS/WINDOWS
- move Doors/Windows option from Import to Modify
http://www.sweethome3d.com/support/forum/viewthread_thread,1724
ADVANCED TAB
VIRTUAL VISITOR
- fixed size, independent of zoom
http://www.sweethome3d.com/support/forum/viewthread_thread,1926
- exact control of VV
http://www.sweethome3d.com/support/forum/viewthread_thread,1825
AERIAL VIEW ROTATION POINT
- set different aerial view rotation point
http://www.sweethome3d.com/support/forum/viewthread_thread,1509
RESCALING AFTER ZOOM
- change zoom behaviour in 2D window
http://www.sweethome3d.com/support/forum/viewthread_thread,1920
ROOM LIGHT
- move ceiling light on/off from Create Photo to Modify Room, so that light can be switched on/of for every room
- make light strength per room adjustable
http://www.sweethome3d.com/support/forum/viewthread_thread,1769
VIDEO
- make it possible to skip a part of the walk in a video with on/off switch for recording
TEXTURES
- texture editor, similar to furniture editor
- make it possible to attach MTL-file to an object
http://www.sweethome3d.com/support/forum/viewthread_thread,1893
- correct texture orientation (at least for elementary objects like boxes, cylinders, triangles, etc)
http://www.sweethome3d.com/support/forum/viewthread_thread,1781_offset,80#8260
- fix issues with transparent textures
http://www.sweethome3d.com/support/forum/viewthread_thread,1827
REPLACE FEATURE
- select multiple objects and replace them with another object
http://www.sweethome3d.com/support/forum/viewthread_thread,1552
IMPORT
- fix issues with DAE import or use FrontFace filter
http://www.sweethome3d.com/support/forum/viewthread_thread,1902
http://www.sweethome3d.com/support/forum/viewthread_thread,1905
- rotate object during import in smaller steps than 90 degrees (on all 3 axes)
http://www.sweethome3d.com/support/forum/viewthread_thread,1574
EXPORT
- export OBJ as a ZIP-file
http://www.sweethome3d.com/support/forum/viewthread_thread,1497
- fix loss of data on export (transparency, light)
- export CSV data for external cost calculation
http://www.sweethome3d.com/support/forum/viewthread_thread,1569
PLUG-INS
- improve current plug-ins and integrate them into program
CREATE PHOTO
- for easy reference, give a number from 1 to 4 to the quality settings; now only Ubuntu users have this, but it's useful for the others as well
USER INTERFACE
The new user interface should offer the possibility to see all relevant info in one screen, including the "texture manager" and the "render manager". Users who don't have a large screen can switch the additional panes off in the Preferences.
Posted by Puybaret at Dec 5, 2010, 9:14:09 PM
Re: Wishlist version 3.1
Thank you Hans for this updated wishlist. Not sure the ones I agree with will appear in version 3.1 though... wink
PREFERENCES
My preference at this time would be to offer to users a better way to enter hours than a text field.
WALLS
The one in the Advanced Edit plug-in could be improved, but I don't mind to program this function in Sweet Home 3D, since many users don't seem to get they should double-click during wall creation to perform the same thing.
DATA ENTRY
I'll try to fix that one, once I'll be able to reproduce it...
DOORS/WINDOWS
Sorry, but I'm really not found of that one and don't want to create an Advanced tab just for this option...
ADVANCED TAB
I'll see if bump maps can be supported at importation time (furniture import and why not texture import), but this won't appear in furniture modification dialog.
VIRTUAL VISITOR
Why not, but we can live without such an option...
Ok for that one, I'll change 3D view modification dialog.
You know my opinion about that one...
I'll see if I can improve it.
ROOM LIGHT
I don't think proposing lights option in 3 different dialogs (photo creation dialog, furniture modification dialog and room modification dialog) is such a good idea. If users don't like the default automatic ceiling lights, they'll place their own lights.
VIDEO
I would prefer to let the choice to edit different videos in the same document (similarly to the stored view points).
TEXTURES
Why not.
Color / Texture / Shininess are options of MTL files. MTL files offer more than that but I don't think it will happen soon.
The current orientation wasn't chosen by chance, and changing the way it's done would have more drawbacks. In the current version, just rotate your objects 180° and you'll see the text correctly oriented on the other side. In the future, applying textures on each side of a cube (including left and right sides), around a cylinder or a sphere will be also available with the wizard I have foreseen in the roadmap.
REPLACE FEATURE
I'll prefer that one appear in a plug-in.
IMPORT
I'm discussing with the author of SunFlow to see what can be done on this one.
That shouldn't be difficult, internal data is already able to handle any kind of rotation.
EXPORT
I still don't understand why you need this feature, since I developed Copy as new furniture plug-in. External 3D tools don't handle OBJ within a ZIP file.
Transparency is fixed. Lights aren't supported in the OBJ format, so that won't happen...
With prices coming from where?
PLUG-INS
I'll try first to handle the roadmap.
CREATE PHOTO
I'll check whether it's feasible.
USER INTERFACE
I didn't start anything about that, but be sure I'll do it with great care. Many reviewers think that Sweet Home 3D user interface is simple, and I just don't want they think the opposite in next major version. wink
Posted by hansmex at Dec 5, 2010, 10:28:58 PM
It's 5 December, everybody is unpacking their presents!
SH3D users about to unpack and admire all the new features
PREFERENCES
I would like to see 19:24 and not 7:24 PM/AM. This is Europe after all.
WALLS
The double-click to auto-connect the end wall to the start wall works fine. Some people don't read manuals. That said, the AdvEdit plug-in could use some improvement.
ADVANCED TAB
Photo realism would certainly improve. Calculation time not :-)
VIRTUAL VISITOR
We can live without vacuum cleaners too. But they make life a lot easier...
Great!
I see people asking for this feature, that's why it's in the list. Personally I think it would be nice to have it, but I don't consider it urgent.
Thanks.
ROOM LIGHT
Maybe I'll ask again next year :-)
VIDEO
Separate videos would mean that you need video editing software to make one movie of it, or accept boring stretches between points. An on/off switch would be rather simple, I think.
TEXTURES
Why not.
Great!!
WOW
REPLACE FEATURE
Maybe we can ask the original authors?
IMPORT
Let's hope it'll be a fruitful discussion.
That would be nice! Rotation round the 3rd axis would still be a desirable feature, but this would be a great first step.
EXPORT
I still don't understand why you need this feature.
I want "one model, one file". Now you get a long list of files and jpg's for every texture.
If the right data are exported, you could manipulate them in a spreadsheet. Prices is one possibility. Calculating the amount af wallpaper or paint is another. I'm pretty good with spreadsheets, I might be able to develop something.
PLUG-INS
CREATE PHOTO
- for easy reference, give a number from 1 to 4 to the quality settings.
Great!
USER INTERFACE
I think SH3D should start up the same as now. In Preferences there's the "Advanced features" tab that switches ON the extra panes. A few people have a second screen and have the "External screen" feature for it. Many people have wide screens, and could use the extra space with these new panes. Also, it would save a lot of switching back and forward for many users.
Posted by wrosun at Dec 14, 2010, 12:58:59 PM
Well i would also like to suggest some thing
1.display roof feature should dispaly roof in Aerial view also.
2. only that satisfied with sh3d v3 for now..hehhe lol
