Print at Aug 17, 2026, 1:35:36 AM
Posted by hansmex at Nov 21, 2010, 8:47:47 PM
DAE model with render problem
Emmanuel,
Is there a solution to get these paintings to render properly?
It seems that every render gives a different result.
Posted by Puybaret at Nov 21, 2010, 9:47:11 PM
Re: DAE model with render problem
Could you give a link to one of the files which cause problem or send it to me?
Posted by hansmex at Nov 21, 2010, 10:27:46 PM
Emmanuel,
Here is the file.
Posted by Puybaret at Nov 21, 2010, 11:05:36 PM
Thank you Hans, it looks like this bug. Not sure I'll be able to fix that one before version 3.0 release... sad
Posted by hansmex at Nov 21, 2010, 11:56:09 PM
Emmanuel,
I think I found a solution! smile
A few days ago PtiNounours posted this message. Having finally been able to install SketchUp, I decided to install the plug-in he mentioned: FaceFront. After activating the plug-in, you "paint" over (parts of) your model and it reorients the faces of the model. In SketchUp you can't see a difference, but there definitely is a difference in the DAE-file when it's imported in SH3D. I treated two paintings this way, then did at least 5 renders, and each one came out correct.
