Advanced render problem
This topic has been viewed 13920 times and has 12 replies
Re: Advanced render problem
Sorry, but Sweet Home 3D support both sides parameter in DAE files.
Hi Guys
Been working on this nearly all night and learnt how to edit the models in sketchup. And you were right - It was a double sided problem. Reversing the faces revealed they were not textured so I textured both sides of all pieces and - problem solved. Many many thanks for all the help (so far - cant proomise there wont be more questions!!!!)
Cheers
Cheers
PtiNounours
- Member
For the methods I have given above, I think, it's the most appropriate methods for exported models. Of course that support SH3D Both Sides parameter in DAE files.
But to understand why this method is the normal method for sketchup, I invite you to visit this link which explains the inversion problem of faces in SketchUp. (In my language Fr, sorry)
http://www.arch-image.com/wordpress/201 ... verseface/
Personally, at the beginning of the Beta, I realized the problem faced when rendering in Sunflow; I then solved the problem by texturing the two sides. I just wanted to understand or was the problem. Especially since the two sides texture made me lose time. Actualy, so I put the faces in the right order, and I chose to export only the visible sides to win on the file size. This gain allows me to select triangulated faces to assurate no problem when importing to SH3D.
joke: a dusty lamp illuminates less. You change the light bulb with a higher power light, or your clean the lamp? [:D] ok. it is no one there. I took the door. [:))]
