Print at Sep 10, 2026, 1:48:33 AM
Posted by mudworm at Nov 8, 2010, 12:40:44 AM
Can I change the Origin of the Image?
When I started the plan, I chose the origin to be by the top-left corner of the plot. But now, my remodel project is mainly in the room that's at the bottom right corner. I will always be zoomed in to work on that corner (so I can get the positions right), but every time, I add a furniture piece, it's by default pasted at grid-position 0-0. then I had to zoom out to have the entire plot visible so I can drag the piece close to where I want to put it and then zoom in again. It gets tiring.
So, can I still change the Origin of the Image now that my work is already in progress?
Sweet Home 3D is so cool! I've been playing with it all day!
Posted by hansmex at Nov 8, 2010, 1:21:10 AM
Re: Can I change the Origin of the Image?
Mudworm,
In version 2.6 and version 3.0 you can do this:
- click in the 2D plan window
- on the keyboard do CTRL-A to select everything
- use the arrow keys on your keyboard to move your entire model
If you use version 2.6 and have the Advanced Edit plug-in installed, there is another way, that potentially is more accurate. Read the tutorial on plug-ins for more info and images.
This is how it works:
- in the menu choose Edit --> Resize
- choose Measure --> Percentage
- make sure to check Keep aspect ratio of and keep the 1:1 value there
- in Position click the bottom-right button
- now change Width to 50 and Height will automatically follow
- click OK
While entering the new width, you will see how your entire model shrinks to half size: walls, floors and furniture. Because you chose the bottom-right button, the entire model will shrink in that direction.
Now repeat the procedure as follows:
- in Position click the top-left button
- now change Width to 200 and Height will automatically follow
- click OK
While entering the new width, you will see how your entire model expands again to double size: walls, floors and furniture. Because you chose the top-left button, the entire model expands from that point.
The result is that your entire model moved to the right and downwards. If you have a simple model, it's (relatively) easy to move your model to precise new coordinates. If you have a more complex model, it may take some calculating. Of the nine buttons in the resize widow, click the top-left button and write down the coordinates of the top-left point of the imaginay square that surrounds your model. Then click the bottom-right button, and again write down the coordinates. Using these, you should be able to work out how to move your model in such a way that a wall ends up on specific X,Y coordinates.
I suggest you practice first with something simple, so that you understand how it works.
Posted by mudworm at Nov 8, 2010, 1:27:08 AM
Hi Hans, thanks so much for the speedy reply! The simple Ctrl-A & move worked perfectly. I should look into the Advanced Edit Plug-in though (I'm on 2.6) since I'm sure it offers a lot of useful features.
Posted by Puybaret at Nov 8, 2010, 10:25:21 AM
mudworm, you should try to place furniture with a drag and drop gesture from the catalog to the location you want in the plan. It's faster and you wouldn't have to move the whole plan...
Posted by mudworm at Nov 9, 2010, 1:48:50 AM
Sweet! I learned another trick. smile
