Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: error with plug-ins eclipse |
| Print at Sep 21, 2026, 1:21:05 AM |
| Posted by white0demon at Aug 24, 2010, 2:59:21 PM |
error with plug-ins eclipseI was trying to create a plug-in and followed the tutorial http://www.sweethome3d.com/pluginDeveloperGuide.jsp I was getting an error with the plug-in I was trying to create so I downloaded this plug-in http://sourceforge.net/tracker/?func=detail&a...d=152568&atid=1127349 since it is for sure working and got the same error. The error is: Invalid plug-in jar:file:/C:/Users/username/Application%20Data/eTeks/Sweet%20Home%203D/plugins/RotateHomePlugin.jar!/org%2Faddy%2Fsh3d%2Fplugin%2FApplicationPlugin.properties: org.addy.sh3d.plugin.RotateHomePlugin not a subclass of com.eteks.sweethome3d.plugin.Plugin Invalid plug-in jar:file:/C:/Users/username/Application%20Data/eTeks/Sweet%20Home%203D/plugins/CopyStylePlugin.jar!/newPlugin%2FApplicationPlugin.properties: newPlugin.CopyStyleAction not a subclass of com.eteks.sweethome3d.plugin.Plugin I don't understand what could be wrong, although it might be something stupid, any ideas? It's the first time I'm trying to develop a plug-in so it could be something easy I didn't notice. If any part of the code is needed (or any other information) I can post it, but right now I only have a message box to appear in the execute and nothing more, everything else is according to the tutorial. |
| Posted by Puybaret at Aug 24, 2010, 3:10:36 PM |
Re: error with plug-ins eclipse Are you sure CopyStyleAction extends Plugin and that you imported com.eteks.sweethome3d.plugin.Plugin (not a Plugin class of an other package)? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by white0demon at Aug 24, 2010, 3:24:45 PM |
Re: error with plug-ins eclipse import com.eteks.sweethome3d.plugin.Plugin; Yeah I think I'm sure. Even if I had it wrong in my plug-in wouldn't it work in the rotate home plug-in? |
| Posted by Puybaret at Aug 24, 2010, 3:36:41 PM |
Re: error with plug-ins eclipse What main class do you run? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by white0demon at Aug 24, 2010, 3:51:27 PM |
Re: error with plug-ins eclipse com.eteks.sweethome3d.SweetHome3DBootstrap |
| Posted by Puybaret at Aug 24, 2010, 5:55:22 PM |
Re: error with plug-ins eclipse Try com.eteks.sweethome3d.SweetHome3D class it should work better! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by white0demon at Aug 24, 2010, 7:03:16 PM |
Re: error with plug-ins eclipse Gives the following error (reason I thought it wasn't this one): Could not find main class: com.eteks.sweethome3d.SweetHome3D. Program will exit. |
| Posted by Puybaret at Aug 24, 2010, 7:22:42 PM |
Re: error with plug-ins eclipse Hum... I'm ok to help but if you're not able to launch com.eteks.sweethome3d.SweetHome3D class, this won't make it... ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by white0demon at Aug 24, 2010, 8:21:57 PM |
Re: error with plug-ins eclipse Any idea why this might be happening though? ![]() |
| Posted by white0demon at Aug 25, 2010, 1:30:24 AM |
Re: error with plug-ins eclipse When I have bootstrap as main class it launches sweet home just not with any plug-in and gives the error I wrote at the first post. This gives any valuable information? ![]() |
Current timezone is GMT Sep 21, 2026, 1:21:05 AM |
