Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Furniture Library Editor released |
| Print at Sep 13, 2026, 8:32:39 AM |
| Posted by ndorigatti at Sep 8, 2017, 3:54:33 PM |
Re: Furniture Library Editor released Hello, i have used version 1.20 of the library a bit on a Mac Osx system (Sierra) with both java 1.6 and 1.8 installed (1.8 as default) and i continue to see in console issue of null pointer exception when clicking. I can use the library for a single operation (add a new 3d model, or rename, or delete). At each operation I have to save, close, reopen and go on, which is very tedious... is there a fix or there will be a fix for this? Do you need further logs/info? |
| Posted by Puybaret at Sep 8, 2017, 4:10:06 PM |
Re: Furniture Library Editor released Please post the stack trace that appears in the console, that could be useful. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ndorigatti at Sep 8, 2017, 5:22:34 PM |
Re: Furniture Library Editor released Hello, this is what happens with 1.21 when: Open the editor, import a 3ds model I already use in my house (and in another library), double click on it in the list of items. From what i can see, is a problem of the table render, shame on you old swing! Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException |
| Posted by Puybaret at Sep 25, 2017, 12:58:35 PM |
Re: Furniture Library Editor released I couldn't reproduce this issue on my side, but maybe I didn't test correctly your "import a 3ds model I already use in my house (and in another library)" suggestion. There should be no difference in how the Furniture Library Editor manages completely unknown 3DS models or the ones you used once in a Sweet Home 3D project. What detail could I have missed? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ndorigatti at Sep 25, 2017, 1:14:31 PM |
Re: Furniture Library Editor released Hi, I think I did not explain correctly what the issue is! The error is not related to what model I use (it was just a specification). This is an issue with Java, AWT/SWING and OSX Sierra. The problem is completely UI related, clicks do not work correctly, events duplicated.... I did the same the other day on a Windows 7 machine and it works perfectly. Currently I'm running java build 1.8.0_91-b14 on OSX 10.12.6 I tryed to force running with the legacy java 1.6 but it did not change anything. I'm quite sure it is something related to OSX, but can't understand what... |
| Posted by Puybaret at Sep 25, 2017, 2:02:14 PM |
Re: Furniture Library Editor released My attempt was made under macOS 10.12.6 with Java 8u144. Maybe it could worth that you try with a more recent Java version? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ndorigatti at Sep 25, 2017, 3:15:04 PM |
Re: Furniture Library Editor released Hi, even with 8u144 it gives the issue when double clicking on an imported forniture. Imported 2 forniture and double clicked on one of the two.... Gives the issue. Is the jar code opensource? Maybe I can try to compile and debug when I have a couple of hours! |
| Posted by sclee at Sep 25, 2017, 3:47:26 PM |
Re: Furniture Library Editor released I use Windows system for a few days ago, I can't enter the furniture Library Editor's work, I will try to remove all JAVA and install JDK-8u144-Window, OK. |
| Posted by DonaS at Oct 14, 2017, 8:11:34 PM |
Re: Furniture Library Editor released I cant get my new created library to save. I just get an error saying "cant save SH3F file" I have tried changing the name and still wont save. I also cant open any of the libraries that came with the software. Sweet Home 3D. I really enjoy this software and I have had it for a Long time, never had the library editor until recently. Thank you |
| Posted by hansmex at Oct 14, 2017, 8:30:05 PM |
Re: Furniture Library Editor released Which operating system do you use ? Which version of SH3D ? ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 13, 2026, 8:32:39 AM |
