Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Furniture Library Editor released |
| Print at Sep 13, 2026, 1:14:02 PM |
| Posted by Puybaret at Jun 4, 2019, 11:22:55 AM |
Re: 1.24 Mac OS Release (Crashing!) Under macOS, you should run the Furniture Library Editor with Java 8 or Apple Java 6. It doesn't work with more recent versions of Java yet. By the way, no need to double post! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ciberyan at Aug 28, 2019, 3:01:30 PM |
Re: 1.24 Mac OS Release (Crashing!) Hello All Hope to be in the right place ... Is there a way (ini file ?) to start the editor in always the same directory ? When I launch the Editor to open a library, it always look in My Documents and would like to redirect to another more convenient folder Thanks in advance |
| Posted by xyzzy at Oct 5, 2019, 8:29:32 PM |
Re: 1.24 Mac OS Release (Crashing!) Hi, I am having trouble opening the furniture library that comes with the store version of Sweet Home 3D on Windows. I would like to sort and filter the items and use the library editor to make it easier to find things. When I open the Furniture.jar file in the lib folder only one item is imported -- an aquarium. Thank you! |
| Posted by Puybaret at Oct 11, 2019, 10:29:16 AM |
Re: 1.24 Mac OS Release (Crashing!) [Update: from version 1.26, the editor is able to open Furniture.jar file that you can save as a furniture library] ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by YGYL at Apr 17, 2020, 4:41:11 PM |
Re: 1.24 Mac OS Release (Crashing!) Nice to see the new version, but V1.25 Will still change the format of the imported file~ |
| Posted by Puybaret at Apr 17, 2020, 6:02:23 PM |
Re: 1.24 Mac OS Release (Crashing!) @YGYL, I wanted to improve the handling of KMZ files, but this would have required some deeper changes in the organization of SH3F files. At the moment, if you want to keep Collada files at their original format, the DAE file should be at the root of the ZIP imported file (this is the case for 3D Warehouse models at Collada format). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by YGYL at Apr 18, 2020, 8:03:17 AM |
Re: 1.24 Mac OS Release (Crashing!)Thank you very much, waiting for your good news Wish you good health~ |
| Posted by T3NZ3N at Apr 21, 2020, 9:08:05 PM |
Re: Furniture Library Editor released For anyone Interested in making this work in the Portable Version: 1. Download JavaPortable8 and install it into your SH3D Portable Directory, into a new folder called "Common"Files", which will create a directory structure that looks like this: (My Program Location Directory)/SweetHome3D-6.3-portable/Common"Files/Java 2. Download JavaPortableLauncher and install it in the SH3D Portable Directory, so it looks like this: (My Program Location Directory)/SweetHome3D-6.3-portable/JavaPortableLauncher Note: So wherever the JavaPortableLauncher is located, there needs to be a folder int eh same directory named "CommonFiles" and inside that a Folder named "Java", which was created when you installed JavaPortable8 3. Put FurnitureLibraryEditor-1.25.jar into the same Portable6.3 folder 4. Right-click FurnitureLibraryEditor-1.25.jar, select "Open With" > Always use this program to open this file type > Choose another program > Browse to the JavaPortableLauncher.exe file in the JavaPortableLauncher folder > OK 5. Right-click FurnitureLibraryEditor-1.25.jar > Send to > Desktop(create shortcut) Drag & Drop your shortcut to Quicklaunch, or wherever you want it. This should now enable you to launch FurnitureLibraryEditor & TexturesLibraryEditor from your Portable Install Folder, which could also be a USB Thumb Drive or something, but can also be anywhere on your Computer. |
| Posted by Bekhadda at Jun 29, 2020, 10:27:41 PM |
Re: Furniture Library Editor Beta released Bonsoir Comme c'est un fichier compressé... Comment l'installer svp Merci d'avance |
| Posted by NikkiSevven at Aug 27, 2020, 7:20:25 PM |
Re: Furniture Library Editor released I'm having some issues with the Furniture Library Editor (Mac OS 10.11.6 and Java 1.8). Here's what I did: 1. Launched the editor. 2. Opened the Contributions library. 3. Changed the categories of some of the models, specifying new category names. 4. Tried to save the modified library, but got an error message that the library couldn't be saved. 5. Changed the name of the file and tried to save it to my desktop instead, which worked. 6. Launched SH3D and imported the modified library. However, while all my newly created categories appeared in the list, most did not contain the models I'd specified. I have no idea what I'm doing wrong or even if I'm doing something wrong. Perhaps someone could walk me through the steps? Or point me to some instructions or a tutorial? Thank you in advance! |
Current timezone is GMT Sep 13, 2026, 1:14:02 PM |
