Print at Jul 21, 2026, 10:24:08 PM View all posts in this thread on one page
Posted by rblue at May 22, 2010, 4:11:49 AM
sad   Sweet Home 3D and Macintosh G3, OSX 10.4.11 don't mix!!!
sad I downloaded the installer package, ran it and indicated that I wanted it loaded to a volume (not the same as where the system lies) where all my third-party applications reside. I have Java 5 update loaded as well. I click on the application and it does launch, it bounces on the dock twice and the menu bar shows Sweet Home 3D - but only that and then....nothing.
I ran the console program and this is what it recorded:
===== Friday, May 21, 2010 9:02:20 PM US/Eastern =====
[JavaAppLauncher Error] value for 'JVMVersion' key in 'Java' should be a VM version string (e.g. "1.4.2")
[JavaAppLauncher Error] value for 'JVMVersion' key in 'Java' should be a VM version string (e.g. "1.3.1")
[JavaAppLauncher Error] CallStaticVoidMethod() threw an exception
Exception in thread "main" java.lang.UnsupportedClassVersionError: com/sun/javaws/Main (Unsupported major.minor version 49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:488)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:106)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:243)
at java.net.URLClassLoader.access$100(URLClassLoader.java:51)
at java.net.URLClassLoader$1.run(URLClassLoader.java:190)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:183)
at java.lang.ClassLoader.loadClass(ClassLoader.java:294)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:288)
at java.lang.ClassLoader.loadClass(ClassLoader.java:250)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:190)
at apple.launcher.LaunchRunner.loadMainMethod(LaunchRunner.java:55)
at apple.launcher.LaunchRunner.run(LaunchRunner.java:84)
at apple.launcher.LaunchRunner.callMain(LaunchRunner.java:50)
at apple.launcher.JavaApplicationLauncher.launch(JavaApplicationLauncher.java:52)
Warning: unrecognized command line flag -foreground
Can anyone help? This program looks terrific and I was looking forward to learning and using it... confused
Posted by Puybaret at May 22, 2010, 12:37:51 PM
Re: Sweet Home 3D and Macintosh G3, OSX 10.4.11 don't mix!!!
I tested Sweet Home 3D 2.4 beta under Mac OS X 10.4 yesterday, and it worked with no problem (it wasn't on a G3 though).
From your console message and a request similar to yours, I guess you're running Sweet Home 3D from the Java Web Start link and not from the installer package.
Try to run it from the installer version.
Posted by rblue at May 25, 2010, 2:03:06 AM
I tried by launching the installer version. Its started as before, this time a color modal window comes up with Sweet Home 3D, then it disappears. And then....nothing, as before.... confused
