Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Furniture Dimensions Plugin |
| Print at Sep 21, 2026, 7:41:37 AM |
| Posted by tdlogicclass at Mar 14, 2026, 12:48:00 PM |
Furniture Dimensions Plugin Furniture Dimensions Plugin Hi everyone, I created a new plugin called Furniture Dimensions that automatically generates dimension lines for selected furniture pieces in Sweet Home 3D. Main features: • Add Width, Height, Depth, and Elevation dimensions • Generate dimensions for each furniture item individually • Generate total bounding box dimensions for multiple items • Show or hide dimension lines in 3D • Change the font size of dimension labels • Delete selected dimension lines How to use: Select one or more furniture items Open Tools → Furniture Dimensions Choose the dimensions you want Click Generate Note: All cabinet doors must be closed before using the plugin. I’ve attached the plugin file https://sourceforge.net/p/sweethome3d/plug-in.../FurnitureDimensions.sh3p and a short video demonstration. Furniture Dimensions Demo https://www.youtube.com/watch?v=0cxOJ4FuwPM Feedback and suggestions are welcome! |
| Posted by dorin at Mar 15, 2026, 8:00:00 AM |
Re: Furniture Dimensions Plugin Welcome aboard. This is a very useful plugin. I recommend that you include the version number in the plugin’s name and include the source code in the package (if possible). I also recommend that you post the SweetHomeLights plugin in this section of the forum. It is also a very useful plugin, but I would like to see a few improvements. Congratulations on the plugins you’ve created! ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by tdlogicclass at Mar 16, 2026, 5:06:03 AM |
Re: Furniture Dimensions Plugin Thank you! Here is the updated package that includes the version number in the plugin file name and the source code inside the package: https://sourceforge.net/p/sweethome3d/plug-in...itureDimensions_v1.0.sh3p For easier access, I have also uploaded the source code separately: https://sourceforge.net/p/sweethome3d/plug-in...t/FurnitureDimensions.zip Regarding the SweetHomeLights plugin (which I’m not completely satisfied with yet), I would prefer to post it at a later time, as I’m currently focusing on some other plugins that I consider more important. Thanks again for your support and suggestions! Best regards, 3D Logic Class |
| Posted by dorin at Mar 17, 2026, 11:27:03 AM |
Re: Furniture Dimensions Plugin I've tried both, and they work. As for the SweetHomeLights plugin, I think it's more than good enough and deserves its own thread in this section. I think it's a bit too complicated for people without much technical knowledge. I'll share more thoughts in the new thread dedicated to this plugin. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by MarioSambol at Mar 17, 2026, 2:56:15 PM |
Re: Furniture Dimensions Plugin I tried the plugin and it is very useful for me. I normally use SH3D but under a different name (Optical Shop 3D) for business purposes. I use it for planning and editing optical shops. I work for the company Presenta Nova d.o.o. and I use our product database with which we equip opticians. I do not use SH3D for rendering, but only for the basic construction of the entire space that I edit and equip with our equipment. I then use it as an exporter to *.obj file, especially the space and especially the furniture. But for a client, a floor plan with the dimensions of the space and furniture is usually enough, unless they are looking for it in *.dwg format. Excellent plugin... |
| Posted by Xlance at Mar 19, 2026, 9:42:54 PM |
Re: Furniture Dimensions Plugin This plugin is beyond AWESOME :-) Furniture Dimensions in Rendered 3D scenes at High Resolution are brilliant :-) Thank You ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
| Posted by tdlogicclass at Mar 20, 2026, 6:29:30 AM |
Re: Furniture Dimensions Plugin Thank you all for your kind feedback and support! I’m aware that the SweetHomeLights plugin still has some limitations. What discourages me the most at the moment is the rendering quality and workflow. For this reason, I’ll probably revisit SweetHomeLights at a later stage. At the moment, I’m focusing on developing two new plugins that I consider a higher priority. I’ll be happy to share them with you soon. Thanks again for your suggestions and encouragement! Best regards, 3D Logic Class |
| Posted by Keet at Mar 21, 2026, 10:55:47 AM |
Re: Furniture Dimensions Plugin This plugin is beyond AWESOME :-) I agree, a very handy plugin that saves having to add individual dimensions. Instant accuracy, great!Furniture Dimensions in Rendered 3D scenes at High Resolution are brilliant :-) Thank You ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by captaincook at Mar 21, 2026, 11:35:40 AM |
Re: Furniture Dimensions Plugin Merci à vous, tdlogicclass. C'est effectivement un plugin très pratique et très bien fait. Félicitations. |
| Posted by Xlance at Mar 21, 2026, 8:21:20 PM |
Re: Furniture Dimensions Plugin Can we rotate vertical dim 90° along y axis (y is up) to show when creating 2d sections by side view plugin :-) ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
Current timezone is GMT Sep 21, 2026, 7:41:37 AM |
