Print at Sep 15, 2026, 5:58:05 AM View all posts in this thread on one page
Posted by GreenBackBone at Feb 19, 2026, 8:03:45 PM
confused   Use all screen realstate in scrolling window manager
Im using Arch Linux with Niri scrolling window manager
in this manager all windows spawn using half the screen
the thing is that when i maximize sweethome3d window
the actual usable realstate stays in half
is there a way to have it use the full mazimize space?
i attach video for visual explanation
Video Of My Trouble
thank you for your time
Posted by GreenBackBone at Mar 12, 2026, 4:33:19 AM
Re: Use all screen realstate in scrolling window manager
no one? :'(
Posted by Daniels118 at Mar 12, 2026, 6:05:43 AM
The program fails to calculate the real size available, most likely because it fails to recognize the dpi, perhaps on a high dpi display. There is a custom setting which allows to override the default scaling, see this post and experiment different values until you get the expected result:
https://www.sweethome3d.com/support/forum/vie...read,5384_offset,10#28822
If it doesn't work at all, you may try to reduce the dpi to a standard value.
MS WINDOWS allows to force the dpi to a specific value when a target program is executing (compatibility option), perhaps you can achieve the same on Linux (using some additional software?).
