Print at Sep 20, 2026, 4:34:48 PM
Posted by Karolita at Jan 27, 2026, 11:27:29 AM
How to add skirting boards?
Is there a way to add skirting boards on walls in Sweet Home 3d?
Thank you all.
Posted by Keet at Jan 27, 2026, 11:53:43 AM
Re: How to add skirting boards?
They are called Baseboards in Sweet Home 3D. Look at the modify dialog of a wall. There you can add and modify a baseboard.
Posted by GaudiGalopin3324 at Jan 27, 2026, 11:53:43 AM
hi. There are several ways to add a baseboard in the program. One of them is to make a skirting board in the form of a thin long box, for example, 7cm high and 1.5 cm thick. You need to assign a texture or color to all visible sides. Enable the Magnet option and glue these baseboard boxes to the walls. The inner corners turn out by themselves, and the outer outer corners need to be carefully connected and aligned. And the main method is embedded in the program itself, look in the wall or floor settings, I don't remember. There's a very normal skirting board.
Posted by Keet at Jan 27, 2026, 12:07:32 PM
@GaudiGalopin3324 we added our answer at exactly the same second laughing
@Karolita GaudiGalopin3324 is correct in the alternative way to add a baseboard with a separate box. The native way has the advantage that the baseboards stretch and move with the wall. You can always enhance the baseboard with custom created molding at the top and bottom.
Posted by Karolita at Jan 27, 2026, 5:05:50 PM
Done!! Thank you all so much for caring and helping!
Posted by dorin at Mar 22, 2026, 10:14:01 PM
Have you tried the Moulding plugin along with the dedicated library? Or the MBC (M for Moulding) plugin, which also adds corners?
Posted by Karolita at Mar 23, 2026, 8:23:39 AM
Thank you, it worked!!
