Total posts in this thread: 7
Previous Thread This topic has been viewed 85591 times and has 6 replies Next Thread
Karolita
Greece
How to add skirting boards?
Is there a way to add skirting boards on walls in Sweet Home 3d?
Thank you all.
[Jan 27, 2026, 11:27:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to add skirting boards?
They are called Baseboards in Sweet Home 3D. Look at the modify dialog of a wall. There you can add and modify a baseboard.
[Jan 27, 2026, 11:53:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GaudiGalopin3324
Russia
hi. There are several ways to add a baseboard in the program. One of them is to make a skirting board in the form of a thin long box, for example, 7cm high and 1.5 cm thick. You need to assign a texture or color to all visible sides. Enable the Magnet option and glue these baseboard boxes to the walls. The inner corners turn out by themselves, and the outer outer corners need to be carefully connected and aligned. And the main method is embedded in the program itself, look in the wall or floor settings, I don't remember. There's a very normal skirting board.
@GaudiGalopin3324 we added our answer at exactly the same second laughing
@Karolita GaudiGalopin3324 is correct in the alternative way to add a baseboard with a separate box. The native way has the advantage that the baseboards stretch and move with the wall. You can always enhance the baseboard with custom created molding at the top and bottom.
[Jan 27, 2026, 12:07:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Karolita
Greece
Done!! Thank you all so much for caring and helping!
[Jan 27, 2026, 5:05:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Have you tried the Moulding plugin along with the dedicated library? Or the MBC (M for Moulding) plugin, which also adds corners?
[Mar 22, 2026, 10:14:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Karolita
Greece
Thank you, it worked!!
[Mar 23, 2026, 8:23:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
