Print at Sep 13, 2026, 7:07:52 PM
Posted by snmavronis at Jan 17, 2026, 11:08:57 PM
Custom Model Editing Using Walls & Floors
It's been years since I made some homemade furniture scale models and I'm trying to remember. I know walls can be curved. But can the edges of rooms/floors be curved by themselves to make shapes or along room walls for curved shapes as well? I forget...hmm.
Posted by sjb007 at Jan 18, 2026, 12:00:45 AM
Re: Custom Model Editing Using Walls & Floors
A floor doesn't have a direct ability to add curvature.
A wall does have the ability to add curvature. You add the wall, then grab the middle gizmo and drag it to make it curve.
If you make an enclosed space with your mix of straight and curved walls then you can create a room with quasi-curved edges by selecting the add room tool and double-clicking in the enclosed space. It will fill the space with a new room object.
Posted by snmavronis at Jan 18, 2026, 12:18:14 AM
That might be cool almost like a mold. I’ll have to see how round the added room edges are.
Posted by Keet at Jan 18, 2026, 12:30:26 AM
Using walls to create a room with curves is a much used method to create model parts. Draw the walls and make sure it is an enclosed area. You can use as many curves as you want. Select the room tool and click inside the walls. It will create the room with all the curves of the walls. You can also click ON a wall. This will create the same room but now extended to the outside circumference of the walls.
Make sure the elevation of the level is >0 otherwise you will get an object after export/import with a height 0 that you can't increase. The exported room will have a height of the floor thickness.
Make sure you uncheck the display of the ceiling before you export and import the room.
You can use a staircase to create a hole in the floor. Place it on a level below the room you create and if necessary elevate it so it creates the hole. Only select the room for export but it will retain the hole. The DodecagonShapes library has a cylinder as a staircase that cuts a round hole.
Walls are often used to create curved model parts too. If you have a level below where you have the walls than the exported walls will be its height+the floor thickness. Keep that in mind and reduce the wall height if necessary.
You can use windows to cut holes in a wall and export only the wall to use as a model part. You can see how this works on the Letters&Numbers page on Dodecagon.nl.
Posted by Keet at Jan 18, 2026, 12:33:49 AM
You can use a much larger wall (x10 or x100) to force a finer curvature. after export/import you can resize again.
Posted by snmavronis at Jan 18, 2026, 2:13:05 AM
Thanks for the suggestions. I'm am going to make our actual 1987 Vaughan Megatrend oak bedroom set. Here is a sketch I made for measurements of my bedroom headboard to start. The real one looks like this image I found from someone's sold used set online. I probably won't be making the outer edges rounded using the SH3D editor (texture shading should help with that) but I will be making the recessed panel areas in layers. I'm tired of using our favorite Swedish store furniture models as placeholders. ;)
Posted by snmavronis at Jan 18, 2026, 11:58:01 PM
I was experimenting with basic shapes by curving wall segments, and the room floor perimeter inner and outer as shapes. For my bedroom set I can use curved walls for the trim curves segments and the room floor for the recessed headboard. I can also do the same for the mirror, dresser trims, and curved drawer panels. As far as curving walls goes that's super great. But too bad it isn't coded in the program to optionally curve each wall sides "independently" of each other. If one could, imagine the infinite shape possibilities for furniture and structural parts by using walls alone.
Posted by Keet at Jan 19, 2026, 6:56:43 AM
Our very respected member Dorin saves your day!
He just released the beta-2 version of his new MBC plugin (Boolean Operations). Download and read about it here .
With that plugin you can create your recesses on both sides very easily: create a shape with the Shape Generator plugin that represents the recess on a side of the panel. This represents the "air" that the recess fills.
Rotate/tilt the recess shape you created into the head board where the recess must be. Select both board and shape and start the MBC plugin. Choose the "Difference" action and run it. What it creates is your head board with the recess cut out of it! Repeat for the other side.
Posted by snmavronis at Jan 19, 2026, 5:21:45 PM
Kent, this looks interesting but Alpha2 not Beta2 version? This may work for my other guest bedroom single bed headboard that is rectangular and has right angle recesses much like your example picture. But not sure how it would work with rounded irregular recesses similar to my Vaughan bedroom furniture that I'm going to recreate. But this is promising for other design applications, although in that forum thread people are reporting it's still a bit buggy as it's still in development for now. I have some compound curves to shape which I'll probably try with curving wall segments and overlapping as needed in the middle section. Then I can export the partial model as OBJ and import as one piece and insert the recessed "backboard" behind it. I'll have to experiment with the oak wood textures to replicate the grain patterns either/or before/during/after the temporary parts export and import to built it up as a completed model. I remember textures may act funny around edges and alignment depending of if it is a wall, floor, or OBJ.
Posted by Keet at Jan 19, 2026, 6:13:18 PM
Kent,
It's Keet smile
Yup alpha, typo from my side.
That is the beauty of this plugin. You can use any geometry, however curved it is, to cut it out from another object. No need to keep to squares.
Sure there will be some bugs, but so far I already made very good use of it and from the example I showed you, it should work just fine for you too.
Yes, the sides of walls and floors sometimes have weird diagonal textures. There's two ways to solve this:
1 - use the Shape Generator to create individual diagonal boards. A generated shape is much easier to texture and if you stick to all generated boards the scaling will be the same for all. Also easy to rotate the textures.
Make sure that each part has its own material name. That will allow you to individually texture and position each part.
2 - use Blender to fix the texture shading. If you want to try that I can explain how to do it.
By-the-way, it is possible to create the rounded sides. Check this thread where I did just that for a gate: https://www.sweethome3d.com/support/forum/viewthread_thread,14114#66507
It did require Blender though...
Posted by snmavronis at Jan 19, 2026, 7:02:48 PM
"Keet" ;)
Looks like we both made typos, sorry. I really wish the SourceForge forum let one edit their posts to correct mistakes.
As far as the geometry goes, I can't use a floor to make a graceful non-segmented curve like a wall. Unless I use walls to make the inner recess edges from walls and plug the middle of these walls with a shape generator solid and combine everything as a single object in order to make myself a "subtraction plug" that way and maybe then use this plugin. I wonder can this plugin tool be used to subtract from or slice into a wall itself?
Posted by Keet at Jan 19, 2026, 7:18:16 PM
This is the Sweet Home 3D forum. You can edit your posts for 3 days (I think). (see at the bottom of this post: it shows that it is edited.)
Not the plugin, it requires furniture objects. But you can export an object and import it as "Door or window" to cut into the wall. This will however cut completely through the wall, not an indention. You can export a mannequin and import it as "Door or window" and create a cutout in a wall with the outline of the mannequin.
But you can always export the wall and import it. Then it is a furniture object that works with the plugin.
Posted by snmavronis at Jan 19, 2026, 8:31:19 PM
I don't see an edit button. At the top of my posts I see Quick Reply, Reply, Quote, Delete Post, and Split. On the bottom I see Printable Version, Profile, PM, Link, Report, and Go To Top. I do see yours is edited however. (Note: I just had to delete my post and repost again because I accidentally typed Quake Reply (button) instead of Quick Reply, LOL.
Anyway, I will try out the plugin and post results when I get time. Thanks again for telling me about it.
Posted by Xlance at Mar 15, 2026, 4:53:50 AM
@snmavronis
for complex curved walls, you can use my cad2walls plugin. You can draw anything in Autocad, Export to coordinates file using .lsp script included then Convert to sh3d walls by using .jar included.
It supports import of walls and polylines.
Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins
Posted by Xlance at Mar 15, 2026, 4:56:51 AM
https://sourceforge.net/p/sweethome3d/plug-ins/56/
