Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Areal View Problem |
| Print at Jul 22, 2026, 3:45:46 AM |
| Posted by Swelst at Nov 30, 2025, 11:27:46 AM |
Areal View Problem Hi I installed sh3d 7.5 on my new Tuxedo-Laptop (TuxedoOS/Kubuntu) I have already sh3d 7.5 on my desktop (Kubuntu KDE Plasma). While I am able zooming close to my house in areal view on my Desktop, i can't do this on my new Laptop ... the view stays in a panoramic state and i cannot come closer ... (while I can do it on my desktop) The difference may be that my kubuntu Desktop works with X11 while the Laptop has Wayland. Is there a way to solve this ? Brgds |
| Posted by Keet at Nov 30, 2025, 11:48:06 AM |
Re: Areal View Problem new Tuxedo-Laptop The difference may be that my kubuntu Desktop works with X11 while the Laptop has Wayland. Switch the laptop to X11?Is there a way to solve this ? https://linuxconfig.org/how-to-use-x-instead-of-wayland-on-ubuntu-22-04 Notice the warning. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Swelst at Dec 1, 2025, 1:55:15 PM |
Re: Areal View Problem I tried this, but it doesnt change ... still no zoom in areal view. |
| Posted by Keet at Dec 1, 2025, 2:04:13 PM |
Re: Areal View Problem Do you have a menu option "Parallel projection" under 3D view? Maybe you have activated it which would prevent zooming. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Swelst at Dec 2, 2025, 10:02:06 AM |
Re: Areal View Problem I don't find any option like that. Where should it be ? |
| Posted by Swelst at Dec 2, 2025, 10:14:44 AM |
Re: Areal View Problem It seems that the zoom is oriented at the "widest" niveau. If I hide the surrounding - niveaus I can zoom closer. I dont have this limitation on desktop .... |
| Posted by Keet at Dec 2, 2025, 10:30:12 AM |
Re: Areal View Problem I don't find any option like that. It's under the 3D view menu option but I possibly have it through one of my installed plugins (Pan3Dview?)Where should it be ? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Swelst at Dec 2, 2025, 10:56:11 AM |
Re: Areal View Problem With Pan3Dview installed I dont have such an option, but ... With this plugin I can zoom in areal view, although it's a bit hard to handle. If I change sight-angle it pops back to panorama and I have to zoom again. It's also very tricky with zoom-scrolling - if you do it too fast its jumping to extreme zoom and back .... |
| Posted by Keet at Dec 2, 2025, 11:09:52 AM |
Re: Areal View Problem It seems that the zoom is oriented at the "widest" niveau. Are you sure it's the same project? A different selected level, which levels are visible, objects over a wider area, a selected object, all of these can change the behavior of the zoom. The exact same situation should result in the same zoom behavior.If I hide the surrounding - niveaus I can zoom closer. I dont have this limitation on desktop .... Have you tried scrolling with an external mouse? Does the same happen if you have the 3Dview pane detached (separate window)? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Swelst at Dec 2, 2025, 1:41:20 PM |
Re: Areal View Problem It is the same file/project shared and updated by a nextcloud server. It Is exactly the same situation, also the external mouse is the same brand. Seperate window makes no difference. The only difference is the machine it is running on. |
Current timezone is GMT Jul 22, 2026, 3:45:46 AM |
