Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: changing line width in PDF export |
| Print at Oct 6, 2026, 12:07:27 PM | |
| Posted by olh at Mar 13, 2025, 10:14:15 PM |
changing line width in PDF export Hello, in a simple room with dimensioning, the lines for the room itself and the lines for the dimensions of each wall have apparently the same thickness in the 2D PDF export. Is there a way to draw the lines for the room thicker, and the lines for dimensions thinner? I looked for an option to change this behavior, but did not spot it in my version 7.5. Thank you. |
| Posted by MarioSambol at Mar 14, 2025, 1:16:00 PM |
Re: changing line width in PDF export I don't think you can change the thickness. You can only change the font size at the moment. |
Current timezone is GMT Oct 6, 2026, 12:07:27 PM |
