Total posts in this thread: 2
Previous Thread This topic has been viewed 3135 times and has 1 reply Next Thread
olh
changing line width in PDF export
Hello,
in a simple room with dimensioning, the lines for the room itself and the lines for the dimensions of each wall have apparently the same thickness in the 2D PDF export.
Is there a way to draw the lines for the room thicker, and the lines for dimensions thinner? I looked for an option to change this behavior, but did not spot it in my version 7.5.
Thank you.
[Mar 13, 2025, 10:14:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarioSambol
Croatia
Re: changing line width in PDF export
I don't think you can change the thickness. You can only change the font size at the moment.
[Mar 14, 2025, 1:16:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
