Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Elevation Issue |
| Print at Sep 9, 2026, 11:02:36 PM | View all posts in this thread on one page |
| Posted by Brian4C at Dec 29, 2024, 9:34:38 PM |
Elevation Issue I just went back to a file I haven't touched in months. I am trying to add a garage door but when I do it inserts about 3 feet above the ground. The issue is that Sweet Home says it has an elevation of zero. I tried copying an existing door and when I paste it, it inserts with the same issue; floating a few feet high but registering an elevation of 0. Any idea what is causing this? |
| Posted by Keet at Jan 7, 2025, 3:54:18 PM |
Re: Elevation Issue Did you draw a floor for your garage? Check the elevation of your level (double click the level tab if you have multiple levels). You might have a level below your 0 level and no floor drawn. In such a case the floor thickness will show as empty space although 3 feet would be a very thick floor. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 9, 2026, 11:02:36 PM |
