Print at Sep 9, 2026, 11:16:52 PM
Posted by Brian4C at Dec 29, 2024, 9:34:38 PM
Elevation Issue
I just went back to a file I haven't touched in months. I am trying to add a garage door but when I do it inserts about 3 feet above the ground. The issue is that Sweet Home says it has an elevation of zero. I tried copying an existing door and when I paste it, it inserts with the same issue; floating a few feet high but registering an elevation of 0. Any idea what is causing this?
Posted by Keet at Jan 7, 2025, 3:54:18 PM
Re: Elevation Issue
Did you draw a floor for your garage?
Check the elevation of your level (double click the level tab if you have multiple levels). You might have a level below your 0 level and no floor drawn. In such a case the floor thickness will show as empty space although 3 feet would be a very thick floor.
